Question about Blaupunkt Montreal CD34 CD Player
Stereo removal I need to remove the stereo from the dash have both tools can't seem to get them to work.Any ideas, am I not using them right.Thanks for your help
  • 65 Answers
They have to be introduced and pushed on both sides , maybe you hear a "click", maybe not, and you may help with a hand if you get the back of the headunit(hu) pushing to you.maybe i can help more if you sendme a closer picture. sometimes you have to take off the plastic molder that are over the edge of the hu
Posted on Sep 17, 2007
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
How do I change the radio out in my 1994 dodge Sat
Disconnect the negative battery cable from the Dodge battery. The negative cable connects the battery to the frame of the vehicle. Use a Phillips-head screwdriver to loosen the cable'c clamp. Remove the clamp from the negative battery lead post.
Remove the dash trim panel that surrounds the stereo and climate control knobs, using a trim panel removal tool. Start at the bottom of the trim and work the tool around the perimeter until the panel is completely removed.
Remove the screws on either side of the Dodge stereo mounting bracket with a Phillips-head screwdriver.
Pull the stereo unit from the dash mounting bracket. Pull the stereo far enough to reach the wiring connections at the rear of the deck.
5
Disconnect the wire groups from the back of the factory stereo. There are four groups, for the antenna, power supply, speakers, and amplifier. Grab the groups by the plastic wire binders, not the wires themselves.
6
Reconnect the negative battery cable to operate the vehicle or any electrical components. Place the negative cable clamp around the negative lead. Use a Phillips-head screwdriver to tighten the clamp until the clamp cannot be moved around the lead by hand.
May 30, 2013 | Car Audio & Video
How to can i replace stereo
see this : God bless you
Review your car's owner's manual to see if it has any tips on removing the current stereo. It may have a diagram of the wiring and the area where the stereo is installed.
  • 2 Disconnect the battery to avoid an electrical short while working with the wiring.
  • 3 Use a screwdriver to remove the retaining screws holding in your car stereo. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
  • 4 Get a pair of DIN tools to slip on either side of the stereo, if the stereo connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the stereo to come out easily. You may need to remove dash panels when bolts hold in the stereo. Take out the bolts and screws that hold the stereo in, and then simply pull it out.
  • 5 Look at the wires on the back of your car stereo. You should see 2 wires attached to the stereo. A wiring clip protects the stereo from vibrations and holds the wiring harness steady.
  • 6 Pry the wires up from the stereo and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
  • Sep 28, 2012 | 1996 Toyota Tercel
    How do you remove radio, from my 2001 dodge neon, that just went dead, for no reason. I replaced the fuse on the side of dash board. Still nothing.
    Safety Precautions
  • Before removing the stereo or any other electrical component, it is vital that you first disconnect the grounding cable from the Neon's battery. The grounding cable connects the battery to the frame or chassis of the vehicle.
    Use a Phillips-head screwdriver to loosen the grounding cable's camp from the negative battery lead. Make sure to rest the clamp away from the negative lead post until the removal is complete.
  • Remove the Dash Trim Panel
  • The dash trim panel that surrounds the Neon stereo needs to be removed to access the stereo. The panel contains, but is not connected to, the climate control knobs on the dashboard.
    Grab the panel at the bottom corners and pry it from the dash. You will likely be able to remove the panel without the assistance of a trim pry tool, but if you are having difficulty removing the panel by hand, wrap a thin cloth around a trim panel removal tool or flat head screwdriver to remove the panel.
    Once the lower edge of the panel is relieved from the panel, you can work your hands (or flat pry tool) around the perimeter to separate the remaining edges.
    Since the panel is not connected to the climate control knobs, you will not need to disconnect the wiring to the knobs. The panel, once free, can be set aside until you replace the stereo.
  • Remove the Stereo
  • The Neon stereo deck is held into the stereo mounting bracket by 10 millimeter bolts on either side of the radio. Remove the bolts and store them in the ashtray for safe-keeping.
    Pull the stereo from the dock. The unit will easily slide from the mounting bracket with an even pull from the left and right of the stereo. Pull the stereo far enough to reach the wiring on the rear of the radio.
    The wiring to the stereo includes the antenna, the power supply and the speaker wires. There may also be patch cables connected if an amplifier is connected to your stereo system. Pull the cables from the stereo. The antenna and power supply are single cables. The speaker wires (and patch cables) will be grouped by wire binders. The plastic wire binders should be pulled as a unit. Do not pull the wires themselves.
    Once the wiring has been disconnected from the stereo, the unit will be completely free from the Neon.
    If you plan to operate the vehicle before installing a new stereo or re-installing the factory deck; reconnect the grounding cable to the negative battery lead. Otherwise, leave the cable away from the negative lead until all of your work is completed.
  • Feb 26, 2011 | 2001 Dodge Neon
    I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
    The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
    Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
    How do I get the radio out of the dash has 4 square holes in the front?
    Hi if you see in the picture by the title of your post you will see that you need a tool to remove the radio the tools has 2 parts to it and each part goes into either side of the stereo you need to push them in really hard and it will then allow you to pull the stereo out.
    you can by the stereo removal clips from any car spares shops and they cost next to nothing without these you will struggle to get it out without damaging the dashboard
    you could also try the well known auction site for these tools as they will cost pennys to buy they really are cheap to buy and without these you will never get the stereo out without causing damage to your car.
    let me know if you need further assistance ok
    plz rate this solution as i have a whole page of unrated posts, thanks
    Aug 30, 2010 | Metra 86 5618 Ford Radio Removal Tool
    Dash removal on 1006 mercury grand marquis
    Hello, to remove the dash follow this steps:
    1. Pry all the woods pieces off of by pulling them away from the dash.
    2. Use two ford radio removal tools to remove the radio in the marquis. Place one tools inside two of the four holes in the front of the radio, and the other tools in the other two holes,Pull them away from each other and out of the dash board. Disconnect the wiring harness from the back of the stereo.
    3. Remove the screw surrounding the radio using a Phillip head screwdriver. Do not forget to remove the two on the other side of the radio.
    4. Remove all the screw around the instrument cluster using a Phillip head screwdriver.
    5. Use the steering wheel tilt level to tilt the steering wheel all the way down .
    6. Gently pry out the dash , making sure to disconnect the two wiring harness behind the dash board panel before pulling it out completely.
    Thanks
    Aug 24, 2010 | 2003 Mercury Grand Marquis
    Hi, i have a 1998 chevy malibu and was wondering how to remove the cd player? i wanted to install a new faceplate so i can get sub woofers in there
    Follow the below steps:
    1. Review your car's owner's manual to see if it has any tips on removing the current stereo. It may have a diagram of the wiring and the area where the stereo is installed.
    2. Disconnect the battery to avoid an electrical short while working with the wiring.
    3. Use a screwdriver to remove the retaining screws holding in your car stereo. Grab hold of the stereo and pull it toward you to remove it from the dashboard.
    4. Get a pair of DIN tools to slip on either side of the stereo, if the stereo connects to the dash using spring clips and bolts. These thin tools slide in easily, release the clips, and allow the stereo to come out easily. You may need to remove dash panels when bolts hold in the stereo. Take out the bolts and screws that hold the stereo in, and then simply pull it out.
    5. Look at the wires on the back of your car stereo. You should see 2 wires attached to the stereo. A wiring clip protects the stereo from vibrations and holds the wiring harness steady.
    6. Pry the wires up from the stereo and loosen them using a pulling/pushing motion. After working the wires back and forth, you should be able to pull the wires straight out.
    I hope the above helps.
    Good luck.
    Aug 23, 2010 | Car Audio & Video
    Im trying to find where i can gt a complete guide on how to install a car stereo from color coding the wires to installing a dash kit
    1. DISCONNECT THE NEGATIVE TERMINAL ON YOUR BATTERY!
    2. For an old stock stereo, you may have to remove the dash or certain parts of it to access the stereo. Do that by locating screws and bolts and taking them off. Make sure to keep them in a safe place.
    3. For an aftermarket stereo, insert DIN tools into each slot on the stereo behind the faceplate. Slide the whole stereo out.
    4. Disconnect the antenna wiring (The wire with the big metal tip)and the stereo head unit wiring (wire harness).
    5. Reconnect the antenna into your new stereo.
    6. Use **** connectors and wire crimps to connect the stock wire harness with a car specific one that is sold seperately. The color of the wires on each harnass should match up.
    7. Reconnect the negative terminal on your battery and see if it works.
    8. Slide the stereo back into the dash and remount the dash that you removed, including screws and bolts.
    hope this will help you
    Jun 05, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
    Removing standard stereo?? How??
    If the existing stereo is a double din, there will likely be screws to remove to get it out on a bracket. Depending on the make and model of the vehicle, there will be more or less to take apart to get it out. There is usually a way to get at the stereo without taking the whole dash apart. Look for seams in the near vicinity of the stereo. There may be screws or pop-clamps/fasteners or both. Screws are usually shielded from view by being installed under a piece of the dash that is merely pinch clamped on (can be carefully pried off - best to use a screwdriver tip wrapped in several layers of paper folded over it or a towel, or your fingers) If screws were used to fasten on the first piece of facing they may be accessible under ash tray or compartment drawer covers, tilting portions of heater/ac registers (some Toyota Tundras, and Sequoias are like this), or just fastened in a slant down position that you cant see from normal sitting position (try looking at the surrounding dash from down close to the seats). There may be a couple of pieces of the dash to remove to get to it. Do some more close looking around and see if any of these tips help.
    May 03, 2009 | Car Audio & Video
    Blaupunkt Montreal CD34 CD Player Logo
    189 people viewed this question
    Top Blaupunkt Car Audio & Video Experts
    xxxxxx xxx
    Colin Stickland
    Colin Stickland
    Marvin
    Marvin
    Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
