Question about General Electric GTR16BBSR Top Freezer Refrigerator
I just moved my refrigerator from one building to another. It was running ok when I un-pluged it to start the move, and now it will not start when I plug it in in the new location. No sound at all, but the inside light comes on OK. Could there be a fuse or breaker that needs to be reset?
  • 358 Answers
If the light inside the refrigerator is on ,that means that you have power coming to it.Check the cold control if not turned all the way to the off position if is off turn it to the oposite side increasing the numbers on the knob.If still doesn't work afte this,check in the back of the refrigerator for any wire that might got disconnet during the moving,if everything is ok you have abad cold control and you have to replace it.Unpluged the fridge ,unscrew the cold control housing take it out(is only 2 wires and a green one thats ground) and put back anew one.Be careful when you installing the new one with the tiny cappilar (silver color ) tube if you brake it or kink it it wont work.
Posted on Apr 17, 2009
Frigidaire upright freezer repair
If all the lights are on, but the compressor isn't coming on, then I would check the compressor start relay and the start capacitor. If the unit was tipped or moved recently, you should not apply power for several hours or you could damage the compressor.
Jan 04, 2012 | Frigidaire Refrigerators
How long should i leave my fridge un pluged after moving.
If the fridge was not laid down on it's side while moving (it stood straight up the whole way) then you can start it immediately. If it was horizontal for some length of time the wait about 2hr. Hope that helped you.
Sep 02, 2011 | Refrigerators
I moved my frig and pluged it back in now it will not get cold
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Aug 28, 2011 | Kenmore Side by Side Refrigerator
My frigidaire side by side quit cooling about two months ago i un pluged it cleand everything and let it sit for about 3 days pluged it back in and it worked for almost 2 months now it is not cooling again...
there sunds to me like there is a problem with you defrost cycle.how ever how need to look for any ice build up in the bottom side of the freezer section.
while the unit is the cooling mode open the freezer door and listen for a fan running if you do not hear a fan running you may need to replace it the door switch should be held in while you are checking this.
then i would alos look at the overload relay and start switch on the compressor.
Jan 31, 2010 | Frigidaire FRS26R4A Side by Side...
No power, system is 4 years old. un pluged system and moved to another plug but still no power
You can open up the unit and check the fuses. Replace them if they are blown. If there not blown then there could be loose wiring. If there is alot of dust build up, take care of it with some dust off.
Jan 17, 2010 | JVC TH-C50 System
My fridge is not cooling,it is a kenmore 596.58642890.we un pluged it for about 5 days with the doors open to try to defrost it,we checked the seals and they are ok,the compressor is running as well as the...
I have a little question about the defrost. Did you see frost build up on the rear panel of the freezer. Is there no hot line coming from com compressor to condenser coil or cold from evaporator? Waiting on your answer, Sea Breeze
Nov 22, 2009 | Refrigerators
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer not working
is there frost building up in the freezer?mike
Nov 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Side by side daewoo american frige freezer
Many possibilities, calcium build up broke loose and a granule is stuck under valve, pivot screw loose or missing, rubbe seat hard or cracked, first see that vale accuater ( the thing you push your glass against is un obstructed and moving freely, then try rapidly opening and closing, to dislodge any thing. If that doesn't work shut off water and disconnect, past ice maker valve, blow
back ward with clean compressed air ( 5lbs psi ) while holding dispenser valve open. Reassemble and test. this should do it , if not start looking further.
Sep 07, 2008 | KitchenAid Superba Architect KSCS25INSS...
5 cubic stand-up chest freezer (Magic Chef) aprox. 3 years old, was immediately pluged-in, after laying on it's side during transport to another apt., before waiting for 12 to 24 hours for the freon to...
If it started cooling your ok. If the compressor got real loud and quit you could be in trouble. The problem comes from the liquid in the system getting on top of the compresser piston. It doesn't always happen when a unit is moved.
Apr 25, 2008 | Refrigerators
General Electric GTR16BBSR Top Freezer Refrigerator Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
