Question about Westinghouse Refrigerators
How to unblocked drain in fridge, Westinghouse BJ434V-R
Hi again , Thanks for the last reply! how do I unblock the drain from inside the freezer , there is a large plastic grill at the back(inside) of the freezer, I have removed the two screws and try to remove it , but wont move , I have try to unblocck the drain from the back with luck!! could I try pouring hot water into the grill or full defrost the freezer and then try to remove the grill ?? Regards Paul
  • Paul Buchanan Apr 17, 2009
    Thanks so very much for your HELP!! I feel confident in removing the grill now , to unblock the drain.
  • 358 Answers
Defrost the frezer and then remove the grill .it has screws and also snaps in plastics on the sides.After this sometimes to get to the drain you also need to removed the back pannel.Always unplugged the unit before do any work.
Posted on Apr 17, 2009
This fridge continually keeps flooding,the drain tube has been cleared but it soon ices up and floods again is it to do with the silver tube position or
It it floods , then drain tube must be partly blocked ! SIMPLES if unblocked , then water will run away.
Mar 13, 2015 | Refrigerators
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
Ihave a Westinghouse BJ434V-R and the bottom freezer is working perfectly, but the top fridge just stopped cooling, is this a thermostat problem if so howis it replaced, Alan
Is the fridge part a separate system? More likely a fan stopped blowing cold air through from the freezer section. If Separate, Thermostat knob prises off end and you will see where wires and sensing phial are located.
May 19, 2012 | Westinghouse Refrigerators
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
I have a fridge freezer and found a small pool of water at back on floor
The drain hole at the inside bottom of your fridge freezer is blocked. locate and unblock
Jul 02, 2009 | Freezers
Hotpoint FFA70S fridge drain blocked
PEACE,
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
Sep 04, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
FZA 81 FREEZER-blocked drain
take back panel off inside freezer and you will probably find drain blocked by ice. melt off with a hairdryer and follow up with hot water till it flows freely away. takes a bit of patience
Aug 31, 2008 | Hotpoint Freezers
Water
You have to unblocked your drain of the fridge & will work after.
Francois
Jun 06, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Top Freezer Refrigerator
i am in uk so not familiar with this product but usual cause is drain hole in centre of gully at back rear of fridge is blocked. (assuming fridge has a conventional evaporator) unblock with a flexible rod of some sort and check water flows away freely
Apr 30, 2007 | Kenmore 63462 Top Freezer Refrigerator
Refrigerators Logo
566 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
