Water just drains, wont fill up washer
Magic chef washer wont fill, water just drains.
    Problem Solver:
  • 6 Answers
The top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Posted on Jul 19, 2009
Dish washer wont spray water
water inlet valve same as washing machine inlet
Aug 01, 2012 | Magic Chef Built-In Dishwasher
When I begin a load of clothes the water will not stay in the machine. It just flows out & never fills the machine enough to begin the wash cycle.
IT SOUNDS LIKE THE DRAIN HOSE IS TOO LOW. IT SHOULD BE HIGHER THAN THE TOP OF THE TUB, OTHERWISE THE WATER WILL JUST GO DOWN THE DRAIN.
Feb 11, 2010 | Magic Chef CAV2000 Top Load Washer
W225LV water flows and drains constantly. Tub won't fill up
HI, this is a siphoning issue.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Sep 20, 2009 | Magic Chef CAV2000 Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Water does not fill
be sure drain hose is not too tight in standpipe ..ck to see how far down standpipe hose is needs to be no more than 6-8 ins standpipe needs to be as high as washer edge from floor..you may have siphoning problem these should correct that
Aug 10, 2008 | Magic Chef CAV2000 Top Load Washer
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washing Machines Logo
609 people viewed this question
Top Washing Machines Experts
