Question about Kenmore Elite HE4 Electric Dryer
Code F11 is coming up; the first few times I solved this myself, but it's stuck for 2 days now, what next?
  • buffalonyman
    buffalonyman May 11, 2010
    What brand and model number?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.**@$%^
Posted on Sep 29, 2010
I have an F11 code on my kenmore front load washing machine
After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
Aug 22, 2014 | Kenmore HE2 Plus Front Load Washer
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I whas temsupend for rrtwo days and i dontnow how to fixs the problem i dont now why they supend me aswell can you please give me a sulosion they say contact customer support bumail to contact them
This is a very common complaint; but there's nothing you can do about it, except wait the 2 days. The suspension is due to Zynga system flagging a possible use of game cheats in use, & this is a completely an automated process which can't be overwritten by customer services, I have tried myself. This will be your 2nd suspension, as they progress by adding a day the next time. You might find in the next couple of weeks, you'll get a 3 day suspension.
Mar 30, 2014 | Zynga Facebook Apps
Vw passat o2 sensor stuck rich
Maybe the O2 sensor has to be replaced. Cleaning doesn't seem to help.
Dec 30, 2013 | 2008 Volkswagen Passat Sedan
Xerox dc 260 incident code 042-322
I have a Xerox DC-250 machine. Few days ago come a fault code 042-322, 1st I replace front door interlock switch & ready the machine. Next day morning when power on the same code come back, then I replace the MCU PWB & ready. Next day again same code, I replace the Xerographic Drawer & ready. Next day same code. So please help me how it possible to solve this problem for permanently?
Feb 05, 2011 | Office Equipment & Supplies
I have entered incorrect radio code for my 01' ML320 Radio and it is know stuck in WAIT. How can I reset radio and re enter Correct code Thanks
leave the radio on for a few days, with the wait displaying, it will display CODE after a few days, 2 - 3 days, then enter the correct code , everytime u enter a wrong code the time increases.
Mar 01, 2009 | 2007 Mercedes-Benz ML320 CDI
Sears He4 has a code F11
Here is what the code means.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Good luck and Please Rate FixYa!
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11 code on my HE4t washer
I fixed this myself for $30 and an hour of time.
Took hi-res photos and created a step by step guide.
www.he4tf11.blogspot.com
Dec 09, 2008 | Kenmore Elite HE4 Electric Dryer
DYSON washine machine fault
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
New MB fits
Earl, it is hard to understand from your post what is the problem?
Are you stack in a black screen with white text showing F2 and F11 or are you able to get pass that, get 3 boot options able start windows and want to remove the operating system boot option screen?
Dec 24, 2007 | Asrock P4i65GV Motherboard
Kenmore Elite HE4 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
