Question about Xantrex Technology XANTREX PROSINE 1800 12V GFCI TRUE SINEWAVE INVERTER Model # 806-1800
No power output from prosine 1800
Everything seems normal but there is no output at the inverter outlets. Batteries are OK. Converter is not pluged in.
You need to check groundings...........
Posted on Dec 01, 2013
4 Suggested Answers
  • 5 Answers
SOURCE: my prosine 2.5 charger inverter intermittent
First try blowing it out the unit with compressed air to see if there is large amounts of accumulated dirt inside, look for black soot on the center of the air outlet side.
Intermittent problems are the hardest to troubleshoot.
If you need more help contact me at sunyout@gmail.com
Thanks.
Posted on Jan 12, 2010
nitrospawn
  • 290 Answers
SOURCE: My Prosine 2000 quit charging. The inverter still
test your batteries if they are still in good condition i.e reading the exact voltage it written on it if it has dropped by 2 volts it needs replacement
Posted on Feb 25, 2010
SOURCE: Xantrex Prosine 1800i "DCDC Shutdown" when connecting AC Load
Hi
Did you find a fault or get it repaired as I have a very similar fault with a Statpower (Xantrex) Prosine 24v 1800i 230v inverter the only difference is that mine faults out with no load on it
Thanks
Posted on Aug 24, 2011
How do i set maps for uk as it wont let me enter country name
Lynn-- I don't understand what you're trying to do. The Xantrex Statpower Prosine 1800 GFCI 24V 806-1850 is an electrical power supply inverter, designed to convert (usually) battery power (direct current) to house power (alternating current). How is an address applicable to this function?
Dec 28, 2014 | Xantrex Statpower Prosine 1800 GFCI 24V...
My Prosine 2.0 display panel displays Panel Fault: Memory error and the display error as well as all lleds are off. The unit looks as if it has no power to it. I reset (power off.power on) the prosine and...
This is a know and widespread problem with the Prosine 2.0, yet when you call Xantrex, they want to charge you to return, repair and/or replace the remote panel. Shame on you Xantrex.
Sep 06, 2010 | Xantrex Technology 806-1800 Prosine...
Hi Schnupfy,
Well, it may be advertised as 1800 watts, but that is a peak. While the 230 VAC may be dead on target, don't expect it to run a mig welder.
Sustained high output is totally dependent upon the power source. What it's doing is protecting itself. DCDC Shutdown indicated 'An overload or system Fault'
Possible problems that would cause this:
  • The load is too high (what is the load?)
  • The power source is intermittent or weak
  • The power source is run through a distribution panel or isolator (Voltage drop)
  • The wiring from the 12VDC source is too long for the gauge used
Click here for a PDF copy of the manual. It is quite well documented.
BEST REGARDS,
MIKE
Dec 18, 2009 | Xantrex Technology Xantrex Xantrex Prosine...
My prosine 2.5 charger inverter intermittent
Thanks.
Sep 14, 2009 | Xantrex Technology XANTREX PROSINE 1800...
What size inverter would I need to run a small 19 inch television
This is just a suggestion. I used my car jumper cable box. My jump box has an outlet for a cig lighter. I have one of those little converters i plug into and i just plug in the tv like normal. I got about 2 to 3 hours out of it. BUt again justa suggestion its stuff i already had.
Jun 01, 2009 | Xantrex Technology Statpower Prosine 1800...
Power save feature on prosine 1800w inverter
i've got exactly the same problem, same inverter, am told its an internal hardware problem, if you was able to fix yours could you let me know how? any advice greatley appreaciated,
cheers, Rob lordrobertj@gmail.com
May 09, 2009 | Xantrex Technology Statpower Prosine 1800...
Xantrex Technology XANTREX PROSINE 1800 12V GFCI TRUE SINEWAVE INVERTER Model # 806-1800 Logo
357 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
