Question about SMC ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub (SKU2218600910)
Looking for the power voltage for a ASOUND petit switch 5 port?
Have purchased asound bar for my tv but tv does not support Bluetooth is their any way ican adapt tv to receive the same
If your TV has an optical port (may have a plug covering the port for safety) and your sound bar has the same port, then obtain an optical cable to connect the two. Otherwise you'll be out of luck.
Dec 18, 2016 | Computers & Internet
What are the voltage and current requirements for the power supply for an Airnet (AES205P) 5-Port Ethernet Switch
powersupply should be +5VDC/2.5A The cost of this power supply may not be worth the trouble since this switch is 16 years old. Newer switches are faster and have better firewall protection.
Oct 24, 2016 | Airnet Computers & Internet
Where is to cut out switch located in a gemini petite oven
if the oven is wired in to the house correctly
all ovens are hard wired into the house wiring
will be a trip switch marked" oven" on the house main power board outside ..
a fautly oven cant be used at all
call electrician for testing
ring for take out or home delivery meals
user manual link
OVEN DEFY GEMINI PETIT CHEF
https://www.defy.co.za/wp-content/uploads/.../Gemini-DBO472-DBO473-Manual.pdf
Oct 10, 2016 | Ovens
What voltage do the AS-480 run on? I mistakenly threw away the transformer.
If you have spark at the coil pick and not at the plug, it can only be one of two things.
Plug wire has a short so try a new one
spark plug is a dud so try a new one.
Aug 19, 2014 | Asound AS 480 Computer Speakers
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
Cnet CSH-800 8-Port Ethernet Switch no power
Check the power adapter with a multi-meter. The voltage on the plug that connects into the Ethernet switch, the voltage reading should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the adapter is faulty and needs to be replaced.
If the voltage of the adapter is OK then the Ethernet switch is faulty and you need to buy a new one.
Dec 11, 2009 | Cnet CSH-800 8-Port Ethernet Switch
Asound Ethernet card drivers for win2000
Try this driver:
http://www.network-drivers.com/drivers/57/57700.htm
Jan 19, 2009 | Asound 22332 Network Adapter
SMC ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub (SKU2218600910) Logo
337 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
