Question about Motorola Mobility SLVR L7 Cellular Phone
Phone resetting Recently my SLVR has habit of resetting itself, the screen turning to black, then white then coming back to the main screen. It seems to occur on keypad inputs as left alone the phone seems fine.
    Brigadier General:
  • 7,752 Answers
Have the keyboard replace to hopefully correct this issue
Posted on Jun 04, 2008
White screen 8530
Have you tried a reset or a reboot? Try these steps:
1. Power off the cell phone by holding down the power button for at least 5 seconds. The screen should turn black. Now, let go of the button and press it again until the screen lights up again.
2. If the screen is still white while holding down the power button, open up the back of the cell phone and remove the battery. Wait for 30 seconds before putting the battery back in, to allow the software to reset itself. Put the battery back in and press the power button until the screen lights up again.
3. If you removed the battery and you still have a white screen, you may have a software issue. Go to a local cell phone repair company and have it replaced or fixed.
Apr 18, 2012 | RIM Blackberry Curve 8520
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
My SLVR will not start with the memory card installed...
you need to have the phone firmware reflash.......take the mobile to a mobile service center and have them reflash the phone for you.
Mar 28, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Moto Slver will not stop blinking hellomoto when i turn it on
try removing the external card if there is one and restart phone without it. if theres no external card, try master reset to factory settings and restart phone, please back up your contacts first before resetting your phone.
Dec 09, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Phone blinking
there a problem with your phone memory, try adding an external card, if it has one. if you do have an external memory, try to remove it, and power-up your phone. if the problem persist it needs servicing.
Dec 05, 2007 | Motorola Mobility SLVR L7 Cellular Phone
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
Black Screen
Hi, before sending it in or taking it to a Motorola repair station, try this. Open phone turn it over so camera is facing you with finger behind and thumb of your right hand sweeze the area between camera lens and the vol up down button to reseat the ribbon connector that is located in that area between the cases. This worked for me and it is worth trying.
Sep 29, 2007 | Motorola Mobility RAZR V3
Freezing/resetting?
Sounds like a glitch in the "flash" program on the phone. I have seen this on the L2 as well. You will have to take it into you local wireless providers store to see if they can "update the flash". Otherwise you can contact your wireless supplier (if you received the phone through them) or contact Motorola directly as they will usually overnight you a replacement. Hope that helps. Best regards, torgo
Aug 13, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
