Question about Abit AV8 Motherboard
Abit beep codes?
The motherboard beeps pauses beeps again pauses and cont.. the # display on the motherboard shows 04.
    Sniper:
  • 66 Answers
Here is a good discussion on the ABIT Beep codes. See if this helps you.
http://www.ocforums.com/showthread.php?t=218664
Good Luck,
Paul
Posted on Apr 17, 2009
Beep codes
Hi I have 1 long beep and 1 long pause and it continues. thats with new ram in it .but it does work with the old ram
Jul 07, 2012 | Abit Computers & Internet
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
My PC with an ABIT motherboard makes a cont beeps although my speakers are off. The beeps stops sometime and then start again. Do you have an idea what should I do. Regards Doron
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 30, 2010 | Abit BG7E Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
I get a long beep then a pause and the beep reats.
More info here
http://www.computerhope.com/beep.htm
Oct 15, 2009 | Abit IC7 Motherboard
Up motherboard beeps and there is no display can
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml
http://www.pcguide.com/ts/x/sys/beep/index.htm
Oct 14, 2009 | Abit KN9 Ultra Motherboard
Abit beep code error and LED code of 87
Hi had similar problem today, 1 long 4 short beeps - so not exactly the same.
I ended up resetting the CMOS - and this fixed my problem.
Hope that helps!
Jun 06, 2009 | Abit AX8 Motherboard
MoBo speaker beeps while using computer
go into your bios and disable any kind of alarms related to your cpu or fans. hope this solves your problem.
Sep 20, 2007 | Abit IC7-G Motherboard
Abit AV8 Motherboard Logo
2,730 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
