Question about Acer Aspire 4520 Notebook
Battery or Screen problem
Okay my sister was using my computer on battery power and the battery ran down and before I could get it plugged it went into stand by mode but now, even though the battery says it's fully charged the screen s really dark. Very, very dark. I can make out certain things. Enough that I was able to get into the settings and try to fix the brightness levels, you know on the balances, power saver and high performance but the screen remains very dark.
  • 1 more comment
  • JoniT Apr 17, 2009
    I have a very similar problem. On rebooting the computer though, screen returns to normal, although very occasionally and for no apparent reason, goes black again, requiring another reboot. On contacting Acer for repair under warranty, they say it should be returned but warn a fee of almost £70 will be charged if it turns out to be software related. Any help appreciated.
  • Leng Yang May 11, 2010
    Look at your function buttons like F11 or F12 (somewhere up there) and see if you find anything that doubles up on those keys to adjust the brightness or darkness of the screen by pressing the FN (fuction) key.
  • ERIC BAKER May 11, 2010
    Have you tried checking the BIOS power setting's? should have something for dimming when running on battery.
Solution? - not sure yet but having read solution by Hector_ahab, tried various F() buttons in conjunction with Fn button. Pressing Fn with F6 switches between black and normal screen on my Acer Aspire 5920. Fingers crossed!
Posted on Apr 17, 2009
Hi my vaxhall insignia battery ran down i started it with jump leads but the odometer went back to zero wanting to sell the car can you please help thanks
Check all your fuses first of all if they are all okay, then you need the computer to be reset when you battery went flat & you jump started the vehicle it would to the vehicle think you had changed the battery just needs to go to Vauxhall garage they should be able to reset then all should be working not a long or expensive job. Hope this helps Best wishes, Malcolm Campbell.
Mar 11, 2017 | Vauxhall Cars & Trucks
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
Feb 03, 2015 | Tablets & eReaders
My battery ran out,so i plugged my laptop back into the outlet,and it refuses to start up again,the blue power light comes on but the screen stays black and after a few minutes the light goes off again.it...
Okay, disconnect the power adapter from the computer and take out the battery. Then take a compressed air can or a vacuum cleaner and clean the bottom of the computer.
Then connect the power adapter only and see if the computer works then (a laptop can work without the battery in when the adapter is connected). If it does work then connect the battery. If it stops working or gives you an error or if the battery shows that it is not charging, then its probably the battery that is faulty.
Thanks. If this was helpful then kindly rate me.
Nov 01, 2010 | Acer Aspire 5500 5570-2609 Laptop
There seems to be no power getting to the computer. checked the fuse. The last time used, the laptop went off because the power ran down and it was not plugged in. Now it will not power up at all.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 18, 2009 | Lenovo ThinkPad T61 Notebook
Non responsive lap top screen
yes remove the battery for some time and the try to open the note book on the charger only if it worked okay if not you musy remove the ram and the hard drive and the dvd and of course the battery from the notebook and then try to open it on the charger only without any of your drivers is connect it will work isa if not you must check if somthing went wrong with the motherboard
Oct 28, 2009 | HP Compaq Presario V6000T Notebook
No output at all
okay close laptop remove battery, open ram / memory compartment, remove memory. try holding down power button for 3 minutes. THEN INSTALL BATTERY , NOT RAM/ MEMORY AND PRESS POWER BUTTON AND IF YOU HEAR A SOUND THAT GOOD NEWS THE SCREEN MIGHT COME ON, OR IT MAY NOT, BUT YOU SHOULD HEAR A BEEP, IF POWER BUTTON REMAINS LIT HOLD DOWN TILL COMPUTER TURNS OFF, THEN INSERT MEMORY/ RAM AND FIRE IT UP. WORK THESE STEPS
Jun 02, 2009 | Dell Vostro 1500 Notebook
Windows Vista not Booting Up
1) Press and hold the power button for 10 seconds to turn off the computer
2) unplug the power cable and remove the battery from the laptop
3) Press and hold the power button while the power cable is unplugged and the battery is not connected so as to discharge the computer
4) Place the battery back again and plug in the power cable.
5) Look for the F8 key on the keyboard.
6) Turn on the computer and start tapping F8. Do not stop tapping F8 until you get to a menu.
7) Use the up and down arrow keys. Highlight Safe mode. Press enter
8) Log in to system.
9) Do a System Restore to the date before you left the computer.
Mar 22, 2009 | Dell Inspiron 1720 PC Notebook
Acer shut down
Souonds like you possibly have a bad power supply. Replace the charger and see what happens
Feb 11, 2009 | Acer Aspire 3680 Laptop
My dell laptop is not turning on with the ac or battery. The LED lights up for a hot min then it turns off. Nothing happens after that. okay. well my dell laptop isnt turning on. the battery is tottally...
Possibley it could be some internal parts. Please try run the onboard diagnostics by holding down Fn and the power button. Make a note of the 3 lights above the keyboard (9,A and the lock key). If it starts for a second and then shut's down, the MoBo will ahve to be replaced. 1501 has known issue and I know this as I work for DELL tech support. Call tech support or chat with them...If the product is under warranty, you should get a replacement.
Pardon my spelling mistakes!!! Let me know if the information was useful or not.
Sep 14, 2008 | Dell Inspiron 1501 Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 4520 Notebook Logo
186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
