Question about Gaggenau EB294/295 Electric Double Oven
Gaggenau EB 194 Double Oven fuse blowing
We have an electric Gaggenau double convection oven that is sporatically blowing the internal 20A micro fuse. It has now happend 4 times in the 18 months we have lived in the house.
The last time it happened, Dec '08, the repair guy replaced the small circut board that holds the two fuses, one for the top oven and one for the bottom. He replace it because it was visable that it had either shorted or was damaged when the fuse blew. He can find no other source of a short. So far, it is only the top oven that has blown, but we never use the bottom oven, except when the top oven isn't working.
The fuse has never blown while the oven is in use. We notice it only when we go to turn it on and it doesn't work. So unless something is happening while the oven is off, it must blow instantaneously when the oven is turned on. It is a static envionment, so there is really no other variable that I can think of. The oven is used on average 3-4X a week and has gone as long as 6 months without a problem...and as little as 2 months. This time it was almost 4 months.
Before I call the repair guy out again to replace the fuse at $120, any ideas on what may be causing this? It is frustrating and expensive. We only have one Gaggenau repair guy in our area and I think he too knows he is only solving the symptom. Suggestions welcome! Thanks in advance.
  • 867 Answers
From your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Posted on Jul 19, 2009
How do I set the time of day on a Gaggenau Wall Oven, EB 985611?
How do I set the time of day on a Gaggenau Wall Oven, EB 276-610?
Mar 08, 2011 | Gaggenau EB984 Electric Single Oven
Gaggenau Wall Convection Oven EB 270 installation instrutions and electrical hook up.
http://www.gaggenau.com/US_en/service.do
you can download installations and user manuals from this site. You'd probably be better putting the full Enr (model) number in the search.
Click where it says 'All manuals available for download' this will open a window where you type in the model. You then get a long list of manual, I presume you want it in english, so pick the one that had EN in the first column and II (installation instructions) in the next column.
Hope the is what you're looking for, all the best.
Jul 05, 2010 | Gaggenau EB 270/271 Electric Single Oven
Lost instructions need help use of rotisserie in my to oven
click on link, click on 'all manuals available for download', anew window will open, type in your model and choose the language and manual you require IU is user manual, ii is installation manual.
Hope this helps
May 19, 2010 | Gaggenau EB 294 Aluminum Double Oven
How to take the door off a gaggenau eb 290 oven
gaggenau oven EB 378-6 door won't close completely It pops back open 2 inches.
Apr 23, 2010 | Gaggenau EB290 Electric Single Oven
ALL POWER OUT HOT-AI9R OVEN EB 663-6
Check the breaker, sometimes they do not turn back on right. Flip it off again and then on really hard...
Also checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4502309-oven_repair_oven_will_not_work_all
heatman101
Apr 10, 2010 | Gaggenau EB294/295 Electric Double Oven
I have a gaggenau 194/195-610 Double oven that takes 25 minutes to preheat to 350%. Is there a quick diagnosis for this problem or do I need a repair service. These ovens have never really worked properly.
It could be a faulty stat or element, an engineer will be able to test them for you
Also he will make sure the cooker is wired properly at the cooker point (correct flex et.)
Sep 21, 2009 | Gaggenau EB294/295 Electric Double Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Gaggenau EB294/295 Electric Double Oven Logo
576 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
