Question about Kenmore 22422 Top Load Washer
I am trying to take of the back of my washing machine how is this done?
How do I take the back off of my Kenmore washing machine?
  • 686 Answers
REMOVE THE 2 SCREWS THAT HOLD THE CONTROL PANEL DOWN, SLIDE IT FORWARD A BIT AND RAISE IT UP. NOW PRY OUT THE 2 BRASS LOOKING CLIPS FROM THE TOP OF THE TOP PANEL PART AND UNKOOK THE DOOR SWITCH WIRE CONNECTOR. NOW YOU CAN REMOVE THE ENTIRE CABINET BY GRASPING IT AND PULL TOWARD YOU UNTIL IT DISENGAGES THE BOTTOM. FROM THERE YOU CAN WORK ON THE COMPONENTS THAT ARE ATTACHED TO THE BACK. REMEMBER HOW THOSE CLIPS GO.
Posted on Apr 17, 2009
  • 6 more comments
  • James Chandler Apr 17, 2009
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Trying to get back cover off to check water hose on Kenmore washe
Try this link http://appliancehelponline.com/topdirectdrivevideo.html
Posted on Jun 03, 2010
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
My clothes still wet after complete circle (done)
There is a problem with the drier in ur washing machine... if it is old try to change it or try for service...!!!!!! But the fact is that there will be 10% moisture in ur clothes after the machine wash...!!!
Mar 22, 2012 | Kenmore Washing Machines
My kenmore elite wahing machine is blinking PF and done of my buttons are working, the mashine will not run at all. I'ts a black top loader, not sure the year.
Hello
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Kenmore Washing Machines
My kenmore elite washing machine has all the lights on but will not pause or start or anything with or without the door closed. should I just unplug the washing machine and plug it back in like a computer?
couldn't hurt to try it! could be the safety interlock that latches the door. on mine, there's a certain 'grace' period that allows adding more clothing before the water reaches a certain level. then the latch locks! stays locked until the load is done. mine's a fridgidaire. so, different.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front-Loading Automatic Washing not draining
Change the brushes or start capacitor for the motor depending on which it takes.. The clothes are proberbly wet due to the motor not spinning the water out of them
Aug 25, 2009 | Kenmore Washing Machines
My kenmore 70 series washing machine does not drain and now will not spin.
bad lid switch,by pass it,remove the 2 plastic end caps on the head if it has them,there is a screw on each side,remove them,flip the head up,unplug the lid switch jack on the washer,,cut the 2 outside wires and wire nut them together,plug back in and your done,let me know how you make out-mike
May 07, 2009 | Kenmore Washing Machines
Kenmore elite washer
need more infor any numbers or codes will check back
Oct 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore oasis washer
Barbara, I took off the control panel and the clear plastic tube that goes to the water pressure switch, the knob that says "water level", was disconnected. I simply put it back on and it worked. Cost was nothing.
Jul 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
197 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
