Question about Mitsubishi VS-70707 70" Rear Projection Television
Big Screen TV
My tv won't turn back on, it was working fine last night
  • 927 Answers
Good day, glojoe;
CHECK IC700 PIN 20 (AC-OFF) FOR 0 VOLTS DC. IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB.
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. I hope this information was helpful, good luck, big IRISH.
Posted on Jul 20, 2008
SOURCE:
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Screen doesnt work, sound works fine. It worked fine last night but wouldnt turn on this morning, why?
is the screen dark?, if is it, see if the TRC filament is light, if is it afirmative, turn a little clockwise the fly back knob that say SCREEN and watch if there is a horizontal line at midle of the tv screen. if is it, your problem is in the vertical stage.
Apr 10, 2010 | Sylvania 6427GG 27" TV
Zenith TV has a big black box in the middle of the screen.
After reading other postings, we figured out that it was the caption box, went to menu and turned it off.
Thanks for the great site, we wouldn't have figured it out without it !
Jen
Nov 15, 2008 | JVC AV-20220 TV
J.v.c. big screen tv 56-58 inch
my jvc big scrreen worked just fine last night and this am i turned it on and the color is greena and red with double vision can you help
May 25, 2008 | Televison & Video
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Mitsubishi VS-70707 70" Rear Projection Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
