Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Crafsman #91725850 riding mower wont start
Has a new starter but wont turn over like there is no power. has new battery.is there a saftey switch that maybe i am missing
  • doublebogie6 Apr 23, 2009
    safety switch under the seat, also there is a fuse on discharge side of mower in wire harness. mine keeps blowing fuses i need to know what proper size fuse belongs in it i have a 20amp but i dont think its right
    Problem Solver:
  • 15 Answers
Try jumping across selanoid and see if it cranks if it does not you need a new selanoid if it does u might have to change the ground wire or change where the ground wire hooks up to the frame my not have a good ground
Posted on Apr 19, 2009
  • Jessica Jun 06, 2013
    is the ground the black wire coming from the solenoid?
Riding mower wont start
check the safety switch on the clutch pedal
May 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Put a new battery on it and still wont turn over
Check all of your safety circuits: Drive safety, blade safety, seat safety.
Naturally, ensure that your key circuit is operating.
Gary
Dec 20, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Will not start< electrical problems.
voltage isn't the problem here. You are correct in using the 12volt battery. However, what you need is more power and power comes from the amperage. Make sure the battery you have, has sufficient CCA (cold cranking amps) for your new starter. Try removing the battery cables and jumping from your car. Make sure you ground the black lead on your car (not hooking the black cable up to the battery directly) if that doesn't start your mower, you have a different problem all together possible being the new stater and hopefully not compression problems steming from the intake and exhaust valves. There are typically saftey switches to shut down or prevent the motor from running. Easy trouble shoot, if the starter kicks over, it's not a saftey switch.
May 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My tractor mower wont start. I have put in a new
If your starter does not have a solenoid on it,you can tell by checking to see if has only one post[no solenoid ]or three posts[solenoid style],then you need to check the starter relay[ or solenoid] that is mounted elsewhere on the machine.If there is a wire that goes to ground on it and one that comes live with the key in the start position the the solenoid[or relay],is defective.If you have no power from the ignition switch in the start position then you likely have a bad safety switch somewhere,usually the pto or park brake switch.
May 12, 2010 | Garden
I have 214 john deere lawn mower starter will not engage,it was fine last fall when i park it,has good battery,just wont engage
try tapping the end of starter with small hammer or wrench, make sure it is in netural, check saftey switch on the gear shift.
Apr 02, 2010 | Garden
My riding lawn mower won't crank. Battery is good, what could it be
Does it crank but not turn over or it wont do anything? If it wont do anything check under the seat if the seat switch isn't making contact it wont start. Thats a saftey feature.
Dec 30, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Riding mower Sears Model 917275660 with a Kohler Engine Model Number SV600, Type number 0001. The engine will not start. I have a new Battery but when I try to start the only thing I hear is the...
So the engine wont turn over at all? Well, we know the fuse is good since the fuel solonoid is getting power. Do you have a test light? Locate the starter solonoid, check for power to the small spade on the starter solonoid when the key is turned to the start position. Be sure the brake pedal is depressed, the pto is disengaged, and that the seat switch is depressed.
If you have power to the small spade then check the large posts for power. The battery side should have power all the time and the starter side should have power when key is turned to start. If you have power from battery and power from key switch but no power to starter then the starter solonoid is suspect.
If solonoid tests good and power is getting to starter but starter doesnt engage then starter is suspect.
If no power to small spade on starter solonoid then you will have to do some back tracking. It could be the key switch, one or more of 3 safety switches or bad wire/ bad connections
Dec 07, 2009 | Craftsman Garden
Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
Nov 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Sep 06, 2008 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
273 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
