Question about RCA 14F512T 14" TV
FPA Lock can't turn Tv on
I have an FPA Lock and I an't get the tv to turn back on what do I do. I tried unplugging the tv and I do not have a remote either so I am trying to do it manually do I need to by a remote universal so I can turn it back on and switch the settings
  • 10 more comments
  • Anonymous Nov 03, 2007
    me too!!!
  • msdunlap Nov 17, 2007
    We have the same issue. We unplugged the TV for several days in hopes that it would reset itself, with no luck. We have no remote and understand that there probably isn't a solution. Any help you can offer would be greatly appreciated!!!
  • olia Dec 02, 2007
  • Laptop1477 Dec 03, 2007
    I don know i even took mine apart i can't figure it out
  • TRUCKK Jan 06, 2008
    I WAS USING THE MENU GUIDE AND TOUCHED SOMETHING AND IT SAID FPA LOCK AND TURNED OFF AND WOULDN'T TURN BACK ON. I DON'T HAVE A REMOTE CONTROL.
  • pat verret Mar 29, 2008
    same
  • Anonymous Apr 03, 2008
    FPA locked no remote, can't unlock
  • Anonymous May 07, 2008
    trueflat, flat screen silver RCA television not sure if it is 14'' it may be 19'' I can't turn my tv on and I don't have the remote. So can you help me get the fpa off the tv. So do I have to get another remote???
  • Takatagirl May 15, 2008
    Ok. My boyfriend went into the menu on our rca and turned on the fpa(whatever that is) then we found out we couldn't turn the tv on from the controls on the tv, so we programmed a ONE FOR ALL UNIVERSAL REMOTE and it fixed part of the problem because now the tv turns on and we can change channels and volume with remote, but NOWWWW when i try to go into menu using the remote to turn the lock off, it won't let me do anything. Does anyone know how to take this fpa off with a remote? The enter or select button don't let it go into the menu to change it and neither does the volume and the channel buttons only let me go up and down in the menu screen. How can I actually change the settings?
  • Anonymous Aug 22, 2008
    i don't have a unaversal remote or a ragular remote is there eney whay yo fix on the controll panel
  • Anonymous Sep 30, 2008
    Exactly the same
  • Anonymous Dec 25, 2008
    FPA LOCK ON
I posted the above - I went to WalMart, bought an $8 remote and a .98 pack of AA batteries. It turned the TV on immediately. Problem solved for less than $10.
Posted on Dec 04, 2007
SOURCE:
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
I have a TruFlat RCA model # 27F520T have lost original remote and FPA lock is on how do I unlock without original remote? Dish universal remote not working to unlock tv, it will pull up menu but cannot...
Try this -
  1. Press menu for main menu.
  2. Press CH + or CH - to highlight preferences.
  3. Press "OK" to enter preferences submenu.
  4. Press CH + or CH - to high light "FPA"
  5. Press VOL + or VOL - to turn the FPA on or off.
  6. Press MENU repeatedly to exit.
  7. Back to normal
  • FPA stands for Front Panel Lock. It makes it so kids don't push all the buttons on the front of your TV. The power button on the TV will still work and the remote will still function as normal.
Regards, Tony
Apr 30, 2011 | RCA TruFlat 27F520T 27" TV
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
May 20, 2009 | RCA 24V511T 24" TV
Rca truflat locked
Hey this same thing happened to me not too long ago and you just have to buy a Universal remote and program it (it should come with the codes to program it to your TV) I think the code is 704 or 702 for RCA... Anywho after that then you can turn your tv back on wit the remote and push menu and Preferences and then FPA off. Its just a parental control block so your kids cant touch the tv buttons and mess with your settings.
Sep 25, 2008 | RCA TruFlat 27F520T 27" TV
Fpa lock
i need some help people......i need to know how to take off the Lock
Jan 20, 2008 | RCA 27F530T 27" TV
RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Oct 02, 2007 | RCA 27F530T 27" TV
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Aug 21, 2007 | RCA 20F420T 20" TV
RCA 14F512T 14" TV Logo
1,505 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
