pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
If the water continuously keeps filling the tub of the washer this would be due to either you have a bad pressure switch or the hose that is connected to the pressure switch that goes down the side of the unit and connects to the tub has either comes off its connection point or has sediment or debris inside the hose itself which would cause the same issue here is also a basic video of how the pressure switch test is done click this link http://www.youtube.com/watch?v=HZZ2bDMspj8 if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to continue helping others in similar situations in the future. Thanks again for using Fixya
Rick
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Either the small plastic tube that goes from the tub to the fill valve switch is loose or broken, or the water fill valve is jammed due to mechanical failure or a chunk of debris got by the inlet screen and is jammed in the valve. Neither of these is a big deal to fix if you are mechanically inclined. Checking the tube involves looking inside the machine from the control panel to the tub. A fill valve is about equal in difficulty to repair as replacing a circuit breaker in a home electric service panel.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
It sounds like a siphon issue. Check
that the drain hose does a high loop before it goes into the drain
pipe. (ie. drain hose loops above the water level inside the tub). Make
sure the drain hose is not pushed too far down into the drain pipe.
Also if the drain hose is sealed to the drain pipe this will create an
airlock and a siphon will occur, allow air to enter between drain hose
and drain pipe connection. This should help you but if there is still a problem let me know and I'll try to assist you further. Good luck!
