Question about Minolta Maxxum HTsi Plus 35mm SLR Camera
Film advancement My camera will take 6 pictures, then the film will rewind. When I get the film developed, the six pictures are good.
Transport mechanism problem; the drag on the film as it is being pulled by the transport motor triggers the rewind mechanism and your camera rewinds the film. Remedy : remove bottom cover and clean loose dirt and anything foreign out of the visible gear-train. Assemble and try again.
Posted on Sep 23, 2007
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
When I turn the knob on the camera to be able to take another picture, the number still stays at zero. What's wrong with my camera?
There are a couple of possibilities that I can think of:
First, film must be loaded into the camera for the picture counter to increment.
Second, if you've loaded film, but the counter still does not change, it is possible the film is not advancing (the film release button/knob/lever that you use to rewind the film may be activated) or the film has slipped off the sprockets on the take-up spool.
If you can stand to lose the photos you may have already taken, just open the back of the camera and make sure the film is advancing when you take a photo.
If you can't possibly lose the photos, rewind the film and take the film to be developed. Try to find a local developer that only charges for the photos that "came out"... This can save a lot of money if only a few frames develop properly (or if none come out!)
Sep 01, 2010 | Pentax K1000 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
I release the small black button on the back of the camera and tried to rewind it but iy won't do it. I am afraid to loose my pictures. Please help me.
On the bottom you have the Film rewind button. On the top you have the film rewind knob with crank . Here are the instructions on how to rewind the film. You can tell you have reached the end of the film by the frame counter and the film advance lever. Either the film advance lever will not turn at all or it will not turn all the way. First press in the rewind button, you may immediately let go of it, its on the bottom as shown before. Then turn the rewind crank clock wise until the frame counter, which counts backwards as you rewind, reaches "S" then open the back cover, remove the film, place it back in its canister and have it developed as soon as possible.
Oct 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to
Mar 21, 2009 | Nikon N55 35mm SLR Camera
Loading/ Unloading the Film
open the film door and charge the shutter. are the drive and take up sprockets turning? if they are then the film was not loaded properly. be sure to push enough film leader into the take up spool bars.
if the spools are not turning then a gear or spring ( advance lever return lock ) is broken.
there are no new parts for the ME Super however some camera repair shops have good used parts that can be used. get an estimate first.
Mar 02, 2009 | Pentax ME Super 35mm SLR Camera
Film developing clear
This problem could have a number of causes,
To check to see if it is a camera fault of developing fault you could try using a cheap colour film in the camera and getting it developed at a normal photo processor.
This will determine in which half of the process the fault lies.
If the pictures from the colour film are the same then it must be a camera usage problem or fault.
If the pictures are ok from the colour film then it will be a problem in either the film being used, developing problem (poor mix of chemicals etc).
This will just speed up the diagnosis a bit.
Oct 02, 2008 | Pentax K1000 35mm SLR Camera
Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Dec 14, 2006 | Nikon N75 35mm SLR Camera
Minolta Maxxum HTsi Plus 35mm SLR Camera Logo
143 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
