Question about Fuji FP-988D 19" Flat Panel LCD Monitor
A/c adapter dead
Power adapter appears to have died. No voltage out at all. Can I use an aftermarket adapter?
  • 1 more comment
  • deddog Sep 16, 2007
    Do I have to open the case to get to it?
  • Anonymous Dec 31, 2007
    I heard a zap saw a flash monitor went dead no more power
  • Russelljohn Jan 03, 2008
    AC adapter overheating the monitor turns off have to wait until adapter cools down.
    Champion:
  • 293 Answers
Hi! there,
It's seems your FP988D / AC Adapter caps it burnt out...Need repair, drop me a note. I'll give you a good price. Thanks [email protected]
Posted on Mar 26, 2008
Got no fuse in the plug, I'll start shopping. Thanks!
Posted on Sep 17, 2007
    Sergeant:
  • 310 Answers
Hey, If you have tried changing the fuse on the plug and still have no joy, you can buy a replacement as long as the voltage, amps, and connection is the same you wont have any problems... All the best john
Posted on Sep 16, 2007
  • John Anderson
    John Anderson Sep 16, 2007
    Hi, i mean just the fuse in the plug.
    But any replacement charger will work even a compatible one
SOURCE:
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
Compaq 610 laptop will not power up, any fix?
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 05, 2012 | HEWLETT-PACKARD Compaq 610 Notebook
Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Mar 29, 2010 | Yamaha Music
I tried to switch on my laptop and it started booting and suddenly went off.From then on its not even booting.Nor does it show the green light which comes on, when you plug it to a power source. Its...
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 09, 2009 | Lenovo R61 T7300 Notebook
Battery power died and the power cord will not charge or trun on the computer
The adapter is faulty or the connector is not making proper electrical contact. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
May 07, 2009 | HP Compaq nx7400 Notebook
Will not recognize AC POWER, Running from Battery only- now battery is dead.
The adapter might be faulty
Check the adapter with multi-meter, the voltage reading should be slightly higher than the voltage output that is printed on the label on the adapter.
May 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Dell Inspiron 500m can´t start
Appears to be a dead/dying power adapter.
Require 2nd opinion on this one before making a decision though.
Apr 12, 2009 | Dell Inspiron 500m Notebook
My D-Link AirPlus Xtrame G is dead
Your power adapter may be dead, check the power connector with a multimeter to see if you have the correct voltage as per the label on the adapter. If not you may only need to buy a power adapter.
You may be able to borrow another adapter with the same voltage and current rating and plug it into your D-Link and if you get a POWER and STATUS lights it proves you have a dead power adapter. If you don't get any lights then it looks like your D-Link is dead.
Nov 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Nov 16, 2008 | Sony VAIO PCG-V505CP Notebook
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
118 people viewed this question
Top Fuji Computers & Internet Experts
Victorman
Victorman
robert
Your Consultant
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
