Question about Intel Motherboard
Help for gateway motherboard power connections, ibm, manual
i really don't know the model type of the motherboard is, but here are some specs i saw...
Machine Type:6824
Model Number: 528
S/N: 99FTF59
Please Help anyone ....
this is an old motherboard..(i guess)
  • joecoolvette
    joecoolvette May 11, 2010
    What Gateway computer did the motherboard come out of?
    Look at the back of the computer next to the Windows Product Key.
    Need those numbers there.
    Or, it might be up on the side/top of the computer case.
    99FTF59 does me no good. If it were the Serial Number of the computer, it would.
    It will be a ten digit letter/number combo, that starts with 00.
    Or it will be a thirteen digit letter/number combo.
  • 797 Answers
The mother board will have numbers on the up side. There you should be able to see the mother board manufacturer, model, and version.
Just because the information is on the case does not mean it is the right one, if som,e one changed it.
Posted on Aug 24, 2009
Motherboard Manual for MS-6389 Ver.1 S462 Motherboard
Hi, This is the closest manual I could find for this motherboard. The link below will lead you to download a manual for the MS-6380LE (the other models close to this were MS-6378 and MS-6390) However, it shouldn't be too different. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=287 Please let me know if you still have problem with connection. Thanks, Lolita
Jun 07, 2007 | Gateway MS-6389 Ver.1 S462 Motherboard...
Configuring a emachine motherboard
Hello here is the homepage:
http://support.gateway.com/support/drivers/search.asp?st=pn&param=4006254R
Manual or tech guide is not to be found at the gateway site.
I don`t know why
I found a manual here:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=1139&MenuID=19&LanID=0
Just select your windows system, and download the manual.
You will need adobe reader. to read the content.
This manual should be the same as your mainboard, but here could be a difference in the drivers.
This manual should show you how to connect the cables.
Hope this will help you
Apr 02, 2013 | Gateway MCP61PM-GM (4006254R) Motherboard
Need technical manual for Gateway ECS MCP61PM-GM VER 2.2 Motherboard Socket AM2 mATX
I don`t know why
The manual should show you how to connect the cables.
Apr 01, 2013 | Computers & Internet
I am wondering what type of motherboard is used in a Gateway W350A laptop. I need to replace mine but I can't find the details to know what I'm looking for. Thanks!
Gateway M305CRV PC Notebook type this in a search like google to check you specs or type, Gateway M305CRV PC Notebook mother board specs...in google or bing
Mar 30, 2010 | Gateway M305CRV Notebook
Gateway computer 310 series wont power up when
It sounds to me like the power switch is plugged into the motherboard incorrectly. I would need to know the type of motherboard you have to get you the proper schematic for hooking up the power switch and reset switch to the board. If you have the manual to the motherboard, there should be a detailed picture showing you how it is to be hooked up. Please let me know the motherboard model for further assistance.
Good Luck,
NOLA Tech
Jan 29, 2010 | Gateway 310 S PC Desktop
Power switch pinout for the 02R4087 motherboard Hi guys I have an old IBM motherboard IBM 02R4087 Netvista Motherboard which appears to be from a Netvista model (NetVista 8182, 8305, 8306, 8309, 8313 ). I...
Progerssed the internet and got a FREE note Free response. Did not have to spend money on your pathetic permium system. Why should you charge for what others give for free?? Parasites
Jul 09, 2009 | IBM (02R4087) Motherboard
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Jun 21, 2009 | Gateway Computers & Internet
    Gateway Intel 850 Socket 478 ATX Motherboard
    http://support.gateway.com/s/MOTHERBD/INTEL/2515762/8508314.pdf
    I found the pdf file(manual) for this motherboard kinda by accident but hopefully this could help someone else out. : )
    Jan 31, 2008 | Gateway (4000782) Motherboard
    Intel Motherboard Logo
    182 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
