Question about Polaroid FLM-2632 Television
FLM-2632, Blue power light on, no sound no picture
Other threads have said to replace the power board. I have removed and inspected mine and there are no visually bad caps. I tested all the wires comming out of the board all red wires show 24v when the unit is powered on and the blue has 5v. Should I look into replacing the powerboard or rebuilding it. Is there some other part that I'd be better to focus my attention to? I doubt its the backlight because I have no sound, typically when the backlight is out there is at least sound or static on the speakers, there is nothing, well other than a mocking blue power light....aaarrrrggggghhh..
  • 7 more comments
  • Axle80
    Axle80 Apr 18, 2009
    Thats what I had figured, but I thought it best to consult someone else before pulling caps. I will start by replacing them and repost with the result.
  • Axle80
    Axle80 Apr 19, 2009
    Began replacing the caps on the power board, everyone of them I pulled off was still juicy inside, so they were probably still good. Oh well, thats the game I suppose, I installed board and turned the TV on and still nothing. I held the flashlight up to the set and there is a picture there but the back light is out. I will order an inverter tomorrow and install it. There is a new problem tho, the picture that is on the board is very garbled, which board is responsible for that? The controller board or the signal board. The garbled picture looks like it could be the polaroid logo only really scrambled. Any ideas so I can order the right board at the same time as the inverter?
    Thanks Joe.
  • Axle80
    Axle80 Apr 19, 2009
    Thanks for the concern, I am a very experienced electronics tinker'er. I know how capacitors work and I know what they do. I built large ones for use in rocket homing signals during my first year of electronics schooling. The caps were dismantled only after being properly removed and discharged and not with a screwdriver. In all my years of doing electronic repairs I've never seen a dried up capacitor. Plenty of blown ones. But I wanted to see if these were infact dried. They weren't. "Juicy" was just a clever way of telling you that you were wrong, without being so blunt. So, are you interested in continuing the assistance?
  • Axle80
    Axle80 Apr 19, 2009
    My goal with this repair is to not exceed the cost of a new set. $300 is my ceiling. That being said, I'll send in the power board for testing. Cheapest place I've found thus far is about $125 for testing/rebuilding. Any other suggestions? Meanwhile, is there a way to test the backlight bulbs, well I suppose them to be CCT's, individually or as a group? Is there a tell tale burn sign or break that would indicate bulb failure? The inverter board looks mint. Yes I know that doesn't mean its good. I agree that the power board should be the main focus at this point, but I had to cut down my money tree for fire wood last week, so lets rule out whatever we can to save the coin. Thanks for your help!
  • Axle80
    Axle80 Apr 20, 2009
    The chart leads me to Change the control box assembly, are they talking about the power board, signal board and tuner board as an assembly? Holy **** that'd be replacing 3 of the 5 boards in one shot...sheesh. The other result I come up with is (according to the chart) to replace the inverter. I think your first impression is where to start, I will be sending in the power board for testing and rebuilding, I will post back in a few days when I get it back. I couldn't find anyone locally that could do it in. Every shop (4) I called claimed no ability and/or interest in fixing a polaroid part. Only one asked for the whole tv and quoted a $100 diagnostic fee. No thanks. So lets begin there. In the meantime, If the CCFT's are like most out there, they run on 12v. The inverter recieves 24, and splits it 10 ways, so, a 9v battery should produce at least a dull glow on each cathode, right? I am asking before attempting, just incase you are sure it will blow it up and burn down the house and such.
  • Axle80
    Axle80 Apr 20, 2009
    After moderately reassembling the tv and testing the leads out of the inverter, the ccfts are getting no power. There is power going into the inverter but nothing comming out, but that still doesn't account for the garbled picture. Back to the drawing board....
  • Axle80
    Axle80 Apr 30, 2009
    Found an inverter for cheap, swapped it with no change. The psb is still out being rebuilt. I will post again when its back.
  • Axle80
    Axle80 May 23, 2009
    My rebuilt powersupply came back and when I plugged it in, it did not fix the problem. so I ordered in a new power supply. It came today. I found that the new one although it had the exact same part number has a different connector along the top. I compared the leads out and modified my wiring to fit. I powered it on and there is still NO change from before. Same black screen with a blue line pattern in the upper 1st quadrant. I went back to testing the boards and found that both boards send 24v to the inverter, and the old one sends 24v to the rest of the set whereas the new one sends 12. I am really stumped here. Not to sound helpless, but now what? I've already dumped $250 into this repair and have nothing to show for it.....AAAARRRRRGGGHhHHHh
  • Axle80
    Axle80 Jul 30, 2009
    Months later I am still at a loss, I have done some more testing and I believe the video board is out. That doesn't explain the backlight not working though, I could still use any help available on this tv if there is someone out there that knows WTH is wrong with it.
  • 15,935 Answers
Post Again later and we will help you more if required.
Thanks for using FixYa!!
Posted on May 08, 2009
HELLO, I HAVE POLAROID MODEL 2700 and i get no blue light and nothing else. i do have 110 volts to the first board that the power cable goes to. where and what should i look for next please?
Posted on Apr 30, 2009
  • 5,660 Answers
Although visual inspection shows no bad caps, this doesn't mean they're not bad. Some caps dry up inside. The Electrolytic paste is dried up. They didn't form the usual Hydrogen gas, and expand the cap, or break the seal, and push paste out.
Also, granted you are getting the proper voltages, but what are the voltages like under a load? There's no way to test this without the proper equipment.
I suggest also that it is the power board. The power supply for the monitor. If you do suspect the backlight to be out, take a flashlight, shine it at the screen, and see if you can make out any images.
I agree though that the backlight is not out, because you also have no sound.
This further convinces me that it's a power board issue.
Posted on Apr 18, 2009
  • 2 more comments
  • joecoolvette
    joecoolvette Apr 19, 2009
    "Everyone of the caps pulled off was still juicy inside, so they were possibly still good"?
    It is with the utmost tact and diplomacy, that I ask you to Stop!
    You're scaring me.
    The recommended procedure for testing a capacitor, is to use a multimeter set to Ohms. Not see if it is 'Still juicy inside'. You test the Microfarad's of the capacitor, and add or subtract the Plus (+)
    or Minus ( - ) percentage rate.
    Electrolytic Capacitors are designed to hold a charge, then let it go all at once. Digital TV's, have capacitors that hold a Large charge! The power board has some of those capacitors.
    These capacitors can hold a charge for weeks, months, or up to a year!
    Should you make a circuit across the terminals, of these capacitors with your fingers, or should your fingers complete a circuit that the capacitors are in, YOU could be the recipient of that charge!
    This can result in a BAD shock or a LETHAL shock!
    A tech will discharge the capacitors before trying to remove them. This is a dangerous task in itself, if not done properly. Many people have tried the old fashioned way, and have melted screwdrivers. Some have pot marks on their faces, from flying molten metal coming off of the screwdriver.
    When those capacitors go bad, they either dry up, or develop Hydrogen Gas inside. They're miniature Bombs!
    More than Anything Else, I am concerned for Your Safety. TV's can be replaced. YOU can't!
    I ask you to stop. Take it to a shop.
  • joecoolvette
    Yes. Now that I know your safety is not a concern, let's continue.
  • joecoolvette
    When an inverter is suspected of being bad, a lot of times the backlight is right behind it. Most of the time it's good to replace both. However, I realize that money doesn't grow on trees, and perhaps replacing the inverter first, then if this doesn't 'cure' the backlight problem, it's time for purchasing the backlight bulb.
    I'm also of the mind, that if the power board is weak at delivering the needed amperes, then the inverter isn't going to get the full power it needs to operate correctly. Would I be fair to say, that the power board should be replaced first, then go on to the other modules, (Boards), and the Inverter/Backlight?
    In my thinking, the Control Board, and the Signal Board aren't going to function as they should, if the needed power isn't there. Granted, you have the voltage, the 'speed', but you may nott have the volume.
    Amperes. This is why I believe the system needs to be tested under a load, and a voltmeter won't get the reading needed. Takes an analyzer.
  • joecoolvette
    The CCT's used in your TV and laptops are Cold Cathode Fluorescent Lamps. Just like any fluorescent lamp, they may or may not show visual signs of failure. Testing them? I don't know the voltages for these CCFL's, do you? (Not a smart aleck answer question)
    AH, here's what I've been looking for->
    Polaroid Plasma TV - 2006 Models
    SERVICE MANUAL
    http://www.audiolabga.com/pdf/FLM3232.pd...
    I would like you to download this, and use the Troubleshooting Flow Chart starting on page 15. Would appreciate hearing your findings.
The power comes on but there is no picture. You can hear the tv humming like it is trying to come on, but it doesn't. I'm trying to locate a motherboard to replace the one I have. this if for a polaroid...
usually the first thing to check is your connections to the tv , if good you may have a power supply or backlighting problem. if connections are good, unplug it first ofr a few minutes the plug it in and try it again. if bad call for service.
Apr 21, 2010 | Polaroid FLM-2632 Television
Tv has no picture but has sound with the dvd player on
Ur LCD inverter board is dead.Must replaced that board to get picture back.The board it uaslly a long board.Tries Shopjimmy.com,Ebay.com for part.
Jan 19, 2010 | Polaroid FLM-2632 Television
FLM 2632 No picture. Screen was blue but now is black.
i would doubt them fully look into this but also look on ebay for parts
Sep 29, 2009 | Polaroid FLM-2632 Television
FLM-2632 October 2006 Won't turn on, no red light, fuse OK
Are you able to with the back off check on all of the PC board 'Especially the power supply board' if any of the fuses are open. If you have a multi-meter to test would be the best. Sometimes you are unable to see the open in a fuse with your naked eye.
This still may be a main power supply issue but more than likely just an open fuse.
Blessings,
A/V Media Tech Guy
Sep 27, 2009 | Polaroid FLM-2632 Television
Help me please i cant miss sunday football
More than likely the lamp ballast power supply has gone bad. If its still under it's 1 year warranty they will fix it for free. If not a good service shop will probably charge you between $100 to 200 to fix.
Blessings,
A/V Media Tech Guy.
Sep 26, 2009 | Polaroid FLM-2632 Television
No picture
Ur back light ic inverter board is dead.
U need a new one.
Aug 29, 2009 | Polaroid FLM-2632 Television
NO Picture or Sound on my FLM 26-32
Either one of two problems, the main power supply has an issue or has gone bad. 'Not supplying the correct voltages to your processing/controlling board' or that you are having problems with your processing/controlling board. My guess is the main power supply board.
A Good TV Service Shop would give you an idea of what the cost of repair should be. Call around.
Blessing,
A/V Media Tech Guy
Jul 22, 2009 | Polaroid FLM-2632 Television
HI HAVE A FLM-2632 THAT ALL OF THE SUDDEN LOST
If it's still under warranty the TV Service Shop will fix it for free if they are a qualified Polaroid servicer. If not I believe you are having problems with the power supply board not sending the Audio board the right voltage. Could be the Audio board itself. A Good TV Service Shop should be able to fix it. May cost you between $100 to 200 for the repair.
Blessings,
A/V Media Tech Guy
Jul 20, 2009 | Polaroid FLM-2632 Television
No picture no sound but have power
the main board on these only last 6-8 months on most of these. These boards are not repairable and will have to be replaced. you can contact
American Systems
13990 Parkeast Circle
Chantilly, VA 20151-2272
1-888-703-5318
USA
for parts and service tech.
Apr 12, 2008 | Polaroid FLM-2632 Television
Polaroid FLM-2632 Television Logo
221 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
