Question about Frigidaire GLEQ642A Electric Dryer
Frigidaire dryer I bought a new front load washer and dryer Frigidaire. I loved the washer, but the dryer is no easy to clean the lint. I can removed the screen lint, but inside is very hard to reach. How can I clean the lint inside? thank you
    New Friend:
My dryer will not spin, it gets very hot model # fd975eso
Posted on Sep 17, 2010
    Scholar:
  • 136 Answers
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Posted on Sep 18, 2007
SOURCE:
My whole house smells like rotten eggs when I run my washer. I have read it could be the lint trap. Where is the lint trap on the Frigidaire gallery front loader?
. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out
Aug 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Flashing container light. what is this? Dryer
Try taking out the lint screen and scrubbing it well in the sink with hot water and a brush. If you havent cleaned out below the lint screen, get a vacuum and a crevice tool and remove any standing lint as well as cleaning the vent. Bosch lint screens clog easily especially if you are a big fabric softener user.
Nov 20, 2010 | Bosch Classixx WVF 2402 Front Load...
I have a frigidaire front load washer, it and the clothes stink.
I have read that using Nu Fresh in a few of your loads will take care of this problem.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Atf6000fs1.. how do I find and clean out the lint trap so I can change my detergent and get this machine to stop stinking!
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 22, 2009 | Frigidaire ATF6000ES Front Load Washer
E68 But big whooping deal. I don't want to call a
Try to vacuum it out or use a small brush. Run water on screen sometimes they look clean and are not.
Jun 10, 2009 | Frigidaire Electric Dryer
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Dryer problem
To herbgirl,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Sep 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Mildew smell on clothes
I have the same machines. Try using an old towel and detergent solution( use rubber gloves) and thouroughly clean the door seal. It can be just full of old lint, dirt, etc. in the grooves. Also try some oxyclean in your next load. That will help get rid of the odor also. These washers stay warm quite a long time and clothing will mildew fast in warm weather, but you probably already know that.
Aug 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLEQ642A Electric Dryer Logo
439 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
