Question about Maytag Neptune MAH5500B Front Load Washer
Replace door gasket maytag neptune washer
Need instructions- is it the same as instructions for whirlpool duet
washer?
  • Anonymous Apr 18, 2009
    mold in wahser
Amigaman
  • 248 Answers
SOURCE: Maytag Neptune Door Boot Change
  Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Posted on Oct 21, 2007
SOURCE: maytag neptune mah8700aww/drum gasket removal/replacement
The bottom of my gasket was torn open all along the bottom. I ordered the gasket but I wanted to see if I could repair it so we could catch up on the wash. I bought some rubber contact cement that cost me under $4.00. I Glued the gasket rubber together by overlapping the the seem a little. Still had a hole in one spot. I had a sheet of rubber around my shop that was about 1/16 of an inch thick and cut it about three inches wide.. I used a little sandpaper to rough it up a little. I cut it in two.
You have to apply contact cement to the gasket and the rubber you are applying it to. ( I dry fit it first to make sure it would fit). Just to make sure it would hold I also glued rubber to the outside bottom of the gasket to reinforce the glued seam. . You need to take off the front panel to do this and there are directions to do this if you search for it. I was able to run the washer in about an hour after the repair.
If your washer is in the basement and are not afraid of getting the floor wet give it a try. I have run the machine with heavy loads for two days and no leaks. I feel confident that the repair will last for a long time. A cheap fast fix. It took me about forty five minutes. Make sure you unplug the machine to do this. Good luck.
Posted on Jun 24, 2008
docjohn174
  • 943 Answers
SOURCE: 2003 Maytag Neptune Washing Machine
HI thanks for your question. i think maytag has an extended warranty, on that part. a design flaw. call Maytag. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
  • 262 Answers
SOURCE: Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Posted on Jan 08, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
What is the best way to clean the mold off the door gasket
I use to have the exact same washer. When Maytag was Maytag before the merger with Whirlpool they suggested using a mixture of bleach and Sunlight power dishwasher detergent. You can also usually find a washing maching cleaner like Tide washer cleaner or Washer Magic. Run it on the longest and hottest wash cycle. Stop the maching during the wash portion and wipe the door seal down well with a rag and ware gloves. Also make sure that the little drain hole in the center of the bottom of the door boot (gasket) is not not blocked up with lint or anything. If your mold problem is really bad you might have to call a repair man out to replace the gasket and clean inbetween your inner and outter tubs.
Feb 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
MHW2000 neptune washing machine: There is a burning smell when washing laundry
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####@@@@@
Feb 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune front loading washingmachine, display is flashing "nd" can you tell me what that means? I cannot find my owner's manual
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.##@@@@
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
The gasket has cracked on the bottom and leaks. I have bought the new door/drum gasket. Where can I find instructions as to how to replace this large gasket/ring that stops water from leaking out the door
This is not to my credit, but I found it on Fix-it--
here is an online manual ,as txt url wraps around you may have to copy paste it .
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing door gasket on maytag neptune MAH5500BWW washer
Apr 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune too much water, will not drain, door won't unlock
you may have something stuck in the pump a sock or a dish towel something small. you will have to get to the pump,,,thats why it wont drain or spin out it cant.
Jan 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Maytag Neptune MAH5500B Front Load Washer Logo
693 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
