Question about Garmin nuvi 200W GPS Receiver
Says No detailed maps found that support routing. The nuvi can not be used without them. Used it to drive home and when turned it back on this is what it said?????
When turn on says No detailed maps found that support routing. The nuvi cannot be used without them.
I finally got an answer to the same problem and here it is. Do exactly what it says to do and it will copy to your NUVI 200W. This is a manual way of doing it without the program logging onto the Garmin website.
Thank you for contacting Garmin International. I am sorry that you are having difficulties updating your Nuvi. I have included a fix that you can do which will fix the error message that you are getting on your unit.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04" at the end of setup.exe". For example it ill end would looking like xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps.
10a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
10b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
11. The file is placed in subfolder named 006-D0783-04.
12. Copy the gmapprom.img file from the folder to the Garmin folder on the Nuvi. Overwrite the existing file.
13. The lower 49 states will be installed on the unit.
If you have any trouble with this fix, or are not comfortable trying it please call into our 800 number and ask to speak to Software Support and one of our technicians will be happy to assist you.
If you need further assistance please call 800-800-1020 number Mon - Fri 8:00am to 7:00 pm central time and someone will be happy to assist you.
Posted on Apr 22, 2009
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
No detailed maps found that support routing the nuvi cannot be used without them
you maps are turned off. go into Tools then Settings. Look for the Map menu. Then Map Info. Make sure you have a check beside the map you want to use. If no map is listed then the next call is the Garmin.
Cheers
Jul 15, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
Help I my nuvi navi says it doesnt have maps???? SOS
garmin are preloaded with maps for routing, never the less, you need to backup with software from www expertgps.com/gps-receivers/garmin-nuvi350asp OR drivehp.com/backup. your set may work after doing that. thanks
Mar 19, 2009 | Garmin Nuvi 350 Car GPS Receiver
No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
"No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
Feb 20, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
303 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
