Question about Toshiba SD-V392 DVD Player/VCR
Dvd player doesn't recognize dvd's of any kind
While showing "reading disc" on the television screen, the player will stop loading the disc and give an "incorrect disc" display on the tv and display "err" on the display of the dvd player.
  • 2 more comments
  • jusguessin Nov 05, 2007
    problem as described above. It happened shortly after dst adjustment. purchased aug 4th, died nov 5th. Will not play dvds (tried a new one)...I have cleaned with dvd cleaner disc, unplugged everything and plugged it back up the following day. I have no idea...
  • Anonymous Jan 04, 2009
    THE SAME THING IS HAPPENING TO ME, EVERYTIME I PUT IN A DVD, ITS SAYS READING, AND THEN IT STOPS AND SAYS INCORRECT DISC, I HAVE TRIED EVERYTHING I CAN THINK OF TO FIX THIS PROBLEM, AND I HAVE NO CLUE, PLEASE HELP!!!! I ALSO HAVE TROUBLE RECORDING PROGRAMS IN THE HIGHER CHANNELS, AND CANT FIGURE OUT HOW TO FIX THAT EITHER!!
    MY DVD PLAYER DOSENT PLAY DVDS! ITS STARTS OUT SAYING READING, AND THEN ITS SAYS INCORRECT DISC, AND ERR IN THE DISPLAY WINDOW. HOW CAN I FIX THIS?
  • Anonymous Mar 21, 2014
    Maxtek player. DV105199
    screen shows NO DISC
  • 286 Answers
Jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
Not even the cleaning disk!
But it will play recorded and burned DVD's.
Any help much appreciated
Posted on Nov 11, 2008
When trying to operate the dvd player it states no read disk when there is a disk in the player
Yes, the DVD player will start with "loading" while it tries to read the disc and figure out what kind of disc it is.
The new-er players will read all sorts of discs, but I have an older one that will only read DVD and MP3 discs.
Any DVD player should be able to load and play an original DVD, but not all will comply if it is a backup copy of your DVD.
If your player refuses to recognize the original DVD, it's time to get rid of it. The cost of repairing it will exceede the cost of a new one.
May 27, 2011 | Vacuums
Samsung dvd player does not read dvd disc.it reads "no disc".
I also have a Samsung Dvd player. If it is a dvd you burned yourself it may not recognize the disc. If you have loaded a purchased or rented disc and it still won't load, I would say the head is dirty or the unit is defective. I would try a head cleaner first.available at most electronics stores If that doesn't work you probably will need to send it in for repair.
good luck
Apr 15, 2011 | Audio Players & Recorders
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
Disk not recognized...loads, but doesn't succeed in playing disk, displaying "no disc" and stops disc spinning. What do I need to do to get the Mintek DVA 8700 to recognize discs. I've opened it to see if...
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 17, 2008 | Televison & Video
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
Screen reads "No Disc"
The laser distance servo may be faulty and the laser assembly catching on the disc.
Apr 11, 2007 | Pioneer DV-250
Toshiba SD-V392 DVD Player/VCR Logo
2,962 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
