Need the code for my radio its been months.
SOURCE: Reset radio code for Acura RL 1996
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. You start at the air vents directly on top of the radio. These tend to be fragile so be carefull when pulling them. You use something skinny like a credit card to wedge between the vents and the trim to release them. Both vents will come directly out in one piece. From there twist off your shift knob. Remove the ashtray. Then pry up the wood trim of the center console. You will then have access to 4 or so screws that hold the radio and climate controls in place. The entire thing comes out as one piece as well. You should see your serial at that point.
SOURCE: Radio code for Acura Integra
Well, ive solved my own radio problem LoLz! On my 1996 Acura Integra LS-S the serial number is located on the back of the radio. The dealership told me to bring it in and they will remove my radio for $9O. That's ridiculous.If you can remove it yourself then you save ninety dollars. Or just do what i did...I squeezed my lil a** under the steering wheel and peeked behind the indash thingy where the radio is held and with a flashlight i was just barely able to see the serial number. I dont know if the serial numbers are all the same for all the makes, models and years like mine. But heres what i got. The serial number is: PH22481 the code for the radio is 26162. I called my local Honda dealer and gave the serial number and they gave me the code over the phone. If it doesnt work try disconnecting the battery for about 6O seconds and try again. Good luck and i hope this helps. FOR I FINALLY HAVE MUSIC!!!! YAY!!!
SOURCE: 1996 ACURA TL RADIO CODE
you need to get the serial number off the radio then go to your acura or honda dealer they should be able to get you the code
SOURCE: Radio code needed for radio in '97 acura 2.5 tl
you need to get serial # ON RADIO and then call dealer they can look up code with correct serial #
SOURCE: I need a radio code for my 1999 acura TL.
Press the numbers 1 and 6 then press the power button this will then show your radios serial number on the display. repeat and press 2 this will tempo. give you tunes.. get the serial number and call dealor. Hope this helps.
HOW DO I DO THAT?
