POSSSIBLE BAD LID SWITCH OR DRIVE MOTOR TO TRANSMISSION COUPLING IS BROKEN POST MODEL NUMBER PLEASE
go to www.repairclinic.com enter your model number and look for part 1195967 this is located between your motor and transmission. to check it out lay the washer on it's back and remove 2 pump retaining clips move pump out of way, next remove 2 motor retaining clips and motor will come out easily check this part out and if any fingers are broken or cracked change it out. If this part is ok re-assemble and change your lid switch. while you have this down clean out your washer's lint catcher part 541811. to see this part scroll down to the red 100 click it and start looking for it. to change the lid switch remove the 2 screws on the control panel and slide it forward and up, now undo the lid switch connector(it looks like it goes through the top panel down, then remove the 2 brass looking clips and pull the top toward you till the bottom disengages. Now cahnge lid switch and wn you re-assemble be sure bootom of cabinet has engaged fully before lowering top back.
