Question about Dryers
NO HEAT - Dryers
    Problem Solver:
  • 7 Answers
Check house fuses first. Then look for broken wire from the motor and then look for broken heat element then look at thermodisk
Posted on Apr 17, 2009
WHAT DOES IT MEAN WHEN HEAT IS SET 66 AUX IS FLASHING
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
Manual for swingman 20e
Hix Heat Press SwingMan 20E: 16"x20" Swing-Away
www.amazon.com > ... > Heat Press Machines
Amazon.com, Inc.Hix Heat Press SwingMan 20E: 16"x20" Swing-Away - MADE IN ... Heat Press 16 x 24 Heat Press by Power Heat Press Sublimation Heat Press ...
HIX Swingaway Heat Presses - YouTube
? 2:30
https://www.youtube.com/watch?v=2rDrtVbd4lw
Mar 7, 2014 - Uploaded by Alpha Supply Co
HIX Swing away heat presses showcasing the Swingman 20P,Swingman 20E, Swingman 15 and the ...
Hix Heat Press Machines For All Heat Transfer Printing ...
www.bestblanks.com/hixheatpress.html
Hix is manufacturing heat press machines for more than 40 years! Why Buy From ... If you should see any of these presses we offer advertised for less, we will meet or beat the price! .... Hix SwingMan 20E Manual 16"x 20" Swing-A-Way - Economy ...... Turncaps into walking advertising for your customers, teams, and more!
Hix SwingMan20E Heat Press Machine - BestBlanks.com
www.bestblanks.com/hixswingman20e.html
Jan 24, 2016 | Hix Heat Press SwingMan 20E: Manual 16"x...
Why doesn't the compressor start in the heat mode
If the compressor is off and the heat coil is on - this is normal for the "E" or emergency heat setting. Check for proper connections between the Heat-pump, furnace(heat source) and the thermostat and that the thermostat is capable of controlling a heat-pump with secondary/emergency heat units. Thermostats designed for this have 4 settings: Cool / off / heat / E(emergency heat). in the "heat" setting, both the Heat-pump and Aux heat work together to maintain temperature. In the "E" setting, only the Aux heat source is used. The "E" setting should only be used in extreme cold - when the Heat-pump can no longer produce heat.
Sep 10, 2014 | LG LP153HD3A - 14,300 BTU, R410A, 9.4 EER,...
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
What does the "auxillary heat"
Auxiliary Heat is used to turn the electric heat strips ON, If the heat pump is not working. Or if the heat pump can't bring the space temperature up to Set Temperature it will display Aux Heat ON....... Assuming you have a Heat Pump System with Auxiliary Electric Heat as Back up...... If the tech didn't install a jumper wire from AUX to W on the subase which is in back of the Display on the Thermostat.....you won't get Auxiliary Heat if the Thermostat is set for Auxiliary Heat. Other wise the thermostat will turn the heat pump on first and then the electric heat (Aux Heat) if it needs it to satisfy the set temperature....... Hope this helps
Apr 21, 2011 | Honeywell Electronic Programmable...
Is the Bryant 661CJ030-A heat pump single- or multi-stage?
Single stage heat pump. But you must have a two stage tstat for backup electric heat. You single stage cool two stage heat. The second stage brings on the electric heat in case the heat pump can not keep up. Wiring goes r y w1 on most heat pump tstats are switchover valve or o terminal. W2 second stage heat or emergency heat. g is fan c is common terminal.Rus
Nov 11, 2009 | Bryant 463AAC008BA Air Conditioner
EM HEAT.... does it stand for ECONOMY HEAT or EMERGENCY HEAT? They both conflict. Someone's misinformed.
It stands for Emergency Heat. (Back up heat) . Normally you will find it on heat pumps. It's used manually when the compressor goes out on a heat pump. It's used automatically by the unit when it's so cold outside the heat pump can't keep up. This happens when there is not enough heat in the air to draw heat from. This happens at around 23 degrees. I hope this explains what emergency heat is and what it's used for.
Oct 16, 2009 | Ruud Central System Air Conditioner
What's the difference between EM HEAT and AUX HEAT?
Sorry, neither of these answers are completely correct.
You have a heat pump (or the wrong thermostat). Let's assume you have a heat pump.
In air conditioning mode, it works like every air conditioner you have ever had, but...
In heat mode, it reverses its operation. Have you ever felt the air coming out of the outdoor unit of your A/C unit? It's hot, isn't it. And the air coming out of the indoor unit (out of the registers) is cold. Now for a heat pump to produce heat it simply runs the air conditioner in reverse and the heat comes out in the house and the cold is released outside. Neat, huh!
Here's the problem with heat pumps...when it is really cold outside the heat pump can't produce enough heat to heat your home. So it has an additional heat source called "Auxiliary Heat". This heat comes on automatically when the house doesn't get warm enough. The source of this heat is based on the region of the country you are in. North/Northeast generally have oil heat, other regions have gas, and still others have to use electricity to heat. In Texas, we usually use electricity as the supplementary heat on heat pumps. VERY EXPENSIVE!
Now the "Emergency Heat"...this is exactly as stated in Solution #2. This is manually turned on by YOU at the thermostat when your heat pump fails. This turns on the auxilliary heaters and turns off the heat pump (remember, the reverse air conditioner). Again, this can be quite expensive to run if your heat source uses electricity! Gas and oil may be cheaper. The emergency heat is only designed (normally) to keep the house livable (not comfortable) until the Heating Tech can get out to you and fix your heat pump.
Something else you should know. It is normal for a heat pump's outdoor coil to frost up during heating mode. It will detect this and go into DEFROST mode and melt the frost off the coil. While it is doing this, it will turn on the auxilliary heater to keep the air blowing in the house at a reasonable "warm" temperature, but it will not be as hot as normal. In fact, heat pumps produce a lower temperature heat than traditional heaters. So the air may feel cooler during heating than you are use to anyway. This is normal and is not a sign of a problem.
So what do you do: Set your thermostat to the temperature you want and set the controls for HEAT/COOL and FAN-AUTO/ON and leave the EMERG HEAT off unless your heat pump breaks.
As always, keep your filters clean and your outdoor unit's coils clean and free of debris.
Hope this explains your question for you!
Thermostat says ''Aux heat on'' and buzzes when we turn on heat
You most likely have a heat pump, the aux heat (usually electric) comes on anytime the room temperature is 4 degrees below the thermostat setting. Does the buzz go off when the aux heat lite goes out? If the aux heat does not shut off then the primary heater (heat pump) is not putting out enough heat to satisfy the thermostat. I need a little more info. Do you have a heat pump? Is it working?
Nov 19, 2008 | Honeywell Electronic Programmable...
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Dryers Logo
Top Dryers Experts
