Question about Acer Aspire M3100 Refurbished Desktop PC - AMD Athlon X2 5600+ 2.8GHz, 3GB DDR2, 500 SATA, DVDRW, Fl
Xp or vista won install on acer spire m3100 after tied to put xp
Hi
I tried to install xp on my acer spire m3100 64x i didnt work i tried to install vista back on it could locate c drive i tried to find the right drives so i can use nlite and install xp but i am having no luck
thanks
Had the same problem. Vista simply sucked. after some investigation it seems that XP install process does not support SATA drives so when installing it, the OS gets the drive size wrong and stuffs up the partitions. tried using the nlite thang to create a install disk with SP3 but that didn't work.
Basically, installed an IDE drive, install XP on that drive and the system works fine using XP Pro SP1&2. XP Home didn't seem to recognise the SATA drive even after installed but it didn't have SP1 or 2. i did need to create the partitions again on the SATA drive using the windows storage management utility.
Also, upgrade the PSU if installing another drive as the standard ACER PSU (250watt) is only enough to run the system as they have it and adding extra power loads is not good.
Posted on May 25, 2009
Try the XP version again for the second time.
Posted on Apr 17, 2009
How do i reinstall windows xp on my spire one netbook d250
You need to make bootable USB Flash diks
Try using this tool, called WinToFlash
Tutorial:
http://downloadsquad.switched.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Best luck!
Jun 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Ethernet-controller drivers for Acer Aspire 5520-5908 XP
Find a USB memory-stick, and find a computer with Internet access and an available USB port.
Put the memory-stick into the USB slot.
Browse to ACER's web-site, and select your specific model of the Aspire line, and select Windows XP, and select network-controllers, and download the device-drivers, and copy them onto the memory-stick,.
Walk the memory-stick to your Acer, and install the device-driver.
May 07, 2010 | Acer Aspire 5520-5908 Notebook
Acer M3100 crashed
I'd suggest there is a possible hardware error. You need to get into the bios and check the temperatures they'll be under 'system health' or similar. Also might be worth running a ram check. Download 'windiag' it's a microsoft program designed to check your ram and it is very good.
Mar 29, 2009 | Acer Aspire M3100 Refurbished Desktop PC -...
Sumsung 2010 driver
Are you running Vista 64x? Just bought a HP Pavilion w/ Vista 64 and experienced the same issues. Apparently Samsung doesn't have drivers suitable for 64x and no longer supports the product. I tried downloading Dell 1100 drivers (same printer) to no avail.
How I fixed it:
Took about a day and a half of on again off agin fiddling with it, but I'm stubborn and hate to toss a perfectly good 3yo printer ;-)
Installed WinRar then downloaded drivers from Samsung for the MPF- 560 for XP 64x.
Decompressed the download, then maunally installed the .inf file
Start>control panel>add Hardware>printers>have disk> then drill down to the .inf file and install. Viola.
Jan 13, 2009 | Samsung ML 2010 Laser Printer
Running Windows Vista 64x and my nds link driver won't install
If you bought the action replay, plug in the cord and a screen will pop up asking you if you want to search for NDS drivers. It will then say no drivers can be found but if you have the disc that came with your NDS to insert it into the computer. You put the small disc that came with the action replay into the cd rom and it will detect the driver. Then you can install the driver.
Jan 01, 2009 | Nintendo DS Lite Console
Bluetooth not installing on WinXP
I looks like Acer designed this Notebook for Windows Vista only.
Have you wiped Vista and installed XP instead? If so is there a particular reason, like an old piece of software not working with Vista?
I would be inclined to put Vista back on it. Vista is much better and safer than XP once you get used to it, Especially on a laptop.
If you really want to keep XP, try looking for an older Acer notebook with the same bluetooth adaptor that came with XP installed and see if the driver works from that, its a long shot though.
Andy
Jun 26, 2008 | Computers & Internet
How to get drivers for acer 5920 laptop
Drivers listing and download links may be found here for an Acer Spire 5920. You need to scroll halfway down for the XP ones.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 18, 2008 | Computers & Internet
Xp
The driver you have downloaded may only support windows Vista. This may be your case. As one technical expert says that all driver versions above 100 are made for vista. So download some lesser versions.
Oct 05, 2007 | Acer Aspire 5630 Notebook
Acer Aspire M3100 Refurbished Desktop PC - AMD Athlon X2 5600+ 2.8GHz, 3GB DDR2, 500 SATA, DVDRW, Fl  Logo
375 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
