Question about HP Compaq Presario SR1303wm PC Desktop
Where do i find a power supply for a compaq presario sr1303wm
  • 62 Answers
    Problem Solver:
  • 8 Answers
You can pretty much get it from any online computer supply store. The part number supplied by Compaq is 5187-1098. You can also Google the PSU using "ATX-300GU" minus the quotes. I recently inherited the same computer and it's missing the PSU so I had to look it up too.
Posted on Jan 20, 2010
3 Suggested Answers
Basilio00920
  • 155 Answers
SOURCE: compaq presario sr1303wm not powering up
Try another power cord first to be sure; if that doesn't works, then replace the power supply.
Posted on Apr 17, 2009
yammy_alf
  • 666 Answers
SOURCE: Compaq Presario SR1265CL replacement power supply
You can replace power supply the higher wattage the better.
Posted on Mar 21, 2010
My Compaq Presario SR1303wm PP150AA cuts off by itself and a little green light on the back starts blinking
it could be overheading or it could be a power supply going bad. where is this green light, is it adjacent to the power cord, like on the back of the power supply unit, or is it adjacent to all the ports?
if the light is on the power supply then replace your power supply. if the light is adjacent to the ports, then remove the side cover of the case and blow the dust out of the cpu heatsink (the cpu heatsink is pretty big, usually aluminum, fin array, topped with a large fan). do not touch any microchips inside the computer, and discharge any static electricity before acessing the inside by touching an unpainted part of the case right after you have removed the side cover. if the heatsink is not dirty, and all the fans are working and well ventalated, then it is likely the power supply.
Mar 12, 2011 | HP Compaq Presario SR1303WM (PP150AAR) PC...
What dvd+r discs are compatible with compaq presario sr1303wm
as long as your dvd-ram drive can read and write dvd+r discs any disc should work.
good luck
-erickpere2
Feb 26, 2011 | HP Compaq Presario SR1303WM (PP150AAR) PC...
I have a second-hand compaq sr1303wm and it was unplugged before it was shut down. Now when its plugged in, the green light in the back is blinking but the cpu will not come on.
if it has a power button on the back of the power supply just turn it off and then unplugg it for about 5 mins then plugg it in and turn on the power supply again before you use the computer power button. if this wont work replace the power supply. this could be costly to fix since you could have fried the cpu when it was unplugged but start and the beginning.
Jan 29, 2011 | HP Compaq Presario SR1303wm PC Desktop
What kind of strongest vedio card can you put in a compaq presario sr1303wm
Hi, mandonut1
Video cards nowadays require a powerful psu if your psu can handle it. Since a HP Compaq Presario SR1303wm have an agp
slot. Agp slots are old now you can find one but you can only play games that require minimal power. this one is the best that i could find
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=2234
Hope it helps,
Thx
Banaple
Sep 03, 2010 | HP Compaq Presario SR1303wm PC Desktop
Compaq presario Sr1303wm power will not stay on...but when I unplug the p7 power supply wire from the motherboard it does stay on...please help.
What does the P7 connector control? How many wires come out of it and what are their color codes? We should be able to fix this. Write me back.
Nov 30, 2009 | Compaq Presario sr1303wm Computer - AMD...
Compaq presario sr1303wm not powering up
Apr 17, 2009 | HP Compaq Presario SR1303wm PC Desktop
I have a Compaq SR1303wm and I unplugged it yesterday and I plugged it back in toay and it won't power up. There is a little flashing green light in the back and it making a little clicking sound
Yep--you need a new power supply. Get one that is the same size (they mostly are) and probably 350Watts. That should do it.
Measure it before you go to the store to be sure it's the correct size.
Or, better yet, take the old one with you.
Apr 14, 2009 | HP Compaq Presario SR1303wm PC Desktop
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all HP Compaq Presario SR1303wm PC Desktop Questions
HP Compaq Presario SR1303wm PC Desktop Logo
261 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
