Question about Whirlpool LER4634J Electric Dryer
Dryer switch My hand-me-down dryer's door has never shut very good. We constantly slam, not knowing this could make things worse. Now it won't come on and I know it is the dryer door switch. Is there anyway I can wiggle it or something to make it work temporarily?
  • 659 Answers
You can bypass the switch by wiring the two wires together. Just remember that while the timer is on, it will not shut off by opening the door. You will have to turn your timer until the unit shuts off. Could be dangerous around small children to do this. Just a warning.
Posted on Apr 17, 2009
  • 116 Answers
Yeah but its unsafe specially with kids! it could stay running if the door was open and wont stop unless you turn the knob or unplug it. thats if it was bypassed.
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
GTWN4250D1WS WON'T START. CHECKED THE POWER CORD, ALL IS WELL. WONDER IF THERE IS A FUSE OR SOMETHING ELSE TO LOOK FOR.
Troubleshooting Why Your Dryer Won Start PartSelect com Electric dryer no start does nothing
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 01, 2017 | Dryers
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Zanussi dryer tc7114W door shuts blows the fuse
Behind the door locking mechanism is a switch, it sounds like from the force a wire might be touching the inside of the machine chassis. Gain access to the back of this switch and check there are not loose cables or cables touching metal.
You should be able to access it by removing the top of the machine, remove the 3 screws and tap the front of the lid with the but of you hand to knock it back and remove it. With a torch look down the inside from of the machine to idenfiy anything loose. Alternativly remove the back of the machine and see of you can see it that way, as that model does have quite a large back access panel.
Keep your screws safe ;)
Oct 03, 2012 | Zanussi TC7114W Electric Dryer
Rear d/s powr window on 2002 RAV4 won't work.
if you dont use that window very often it might just be stuck to the rubber around the top and side of window.you can have someone hold down the switch while you take your hands one on outside of window and one on inside of window and slap at a downward motion and you can also slam the door a few times while someone is at drivers door holding switch down. if this dont work it is most likely the window motor. good luck let me know if i was any help at all
Jun 16, 2011 | Toyota RAV4 Cars & Trucks
I have a Maytag PYE2200AYW electric dryer. we had problems a few weeks ago and discovered that the blower wheel was cracked, so we replaced it (part # 31001317). Then a couple days later it just stops and...
Check the thermal fuse and thermostats again to eliminate them as suspects. Both should be zero ohms at room temperature. If you eyed the entire duct system from lint filter to outside of the house for lint, then these are probably OK.
One thing that will shut down a dryer: a defective door switch. If you turn the timer on with the door shut and can hear or see it progressing (running) then the door switch is OK.
If your door switch is operating marginally, the heat can expand the body of the switch and open the circuit (and shut the dryer off until it cools). Check the switch with an ohmmeter with the dryer disconnected from power.
A loose spade terminal on this switch (or anywhere else) can do this too.
Also, a misaligned door or defective door clasp might do this after heating up.
Keep thinking 'heat expands' and you might find it.
The only other thing left is a defective timer.
Good luck from Detroit, MI.
Jun 11, 2011 | Maytag PYE2200 Dryer
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Dryer won't come on
Was it the dryer door he slammed shut or the house door? If it was the dryer door, then TheMobilian's answer is on the nose. If it was the house door that was slammed and it tripped the circuit breaker to your house, then you have something else entirely going on. Does your dryer have an electronic control panel (totally smooth surface), or does it have the knobs and buttons? What model number do you have?
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
759 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
