Question about Samsung ML 1710 Laser Printer
Printer- On Line/Error
Hi, my name is Razeem and i have the ML-1710 Laser Printer and for some reason it has stop working. Whenever i turn it on it shows a Error light (red light). And it doesnt do anything after. Please if someone can help me troubleshoot this problem, i wouls apprieciate it... Thank youu
  • 705 Answers
Download the status monitor for the ML-1710 and when you switch on the machine the monitor should help to give you an indication of what the error is. Post that info back here for further help. Unfortunately there is insufficient information here to help you further. The status monitor may give you an error code - this will help us help you further.
Posted on Sep 16, 2007
SOURCE:
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Nov 27, 2009 | Samsung ML 1710 Laser Printer
I have a samsung ml-1710 laser printer. Was wrking
Power off the printer, disconnect/reconnect the printer cable, power on the printer, reboot your workstation.
If that doesn't work, in Control Panel - Printers, delete the icon for your printer. Disconnect the printer cable. Reboot your workstation and log in. Reconnect the printer cable and see if the printer is recognized. Install the printer driver.
Jun 12, 2009 | Samsung ML 1710 Laser Printer
How you install these printer without disc
I think there is a lot of driver software inside the Win vista instead to have CD that when you connect printer with computer and follow the steps then chose the correct name that is Samsung ML 1710 Laser Printer ..
Jan 08, 2009 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer, over active feeding
sounds like there's something in the print queue..disconnect it from the computer, and try it again.
Feb 19, 2008 | Samsung ML 1710 Laser Printer
Samsung ML-1710 on-line problem (red) alert. ? Thank you.... My Name's : Evren DANACI My MSN address : [email protected] i 'm from Turkey / Samsun.
selam bende samsundan tanisallimmi?sizi facebokkta gördüm ve begendim tanismak istiyorum boy 1.70cm göz yesil omuzlara kadar sari saclarim var kilom 60kilo ben buyum sizde isterseniz cok tanismak isterim
Feb 12, 2008 | Samsung ML 1710 Laser Printer
Samsung ML-1710 Laser Printer
Hi, On another posting of a similar problem, I proposed this solution: In some instances, the PC switches off a USB port. You may have to un-check "Allow the computer to turn off this device to save power." This is in your Device Manager/Universal Serial Bus Controllers/USB Root Hub. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Apr 24, 2007 | Samsung ML 1710 Laser Printer
Printer problems
Hi, On two other postings of similar problem, I proposed this solution: In some instances, the PC switches off a USB port. You may have to un-check "Allow the computer to turn off this device to save power." This is in your Device Manager/Universal Serial Bus Controllers/USB Root Hub. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Mar 31, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
420 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
