Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The freezer section is not freezing, not making ice, water is running out of bottom of frig.
Freezer section is not freezing and not making ice.
  • 121 Answers
See if the back wall of the freezer is full of ice if so you have a automatic defrost problem timer limit switch or heater and check the fans also
Posted on Apr 17, 2009
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER AND ICE INSIDE MY FRIG
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
These are general instrutions for most top freezer refrigs. but if you need more specific directions dont hesitate to ask Thanks Peyton
Mar 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
