Question about Sony VPL-CX6 Multimedia Projector
Hi i ve connect a projector to laptop , on projector screen show only desktop background but nothing else ,i think i shoud do something with mornitor 1 and 2 to get all the programme on laptop up on projector screen .but i have no idea what to do ?anyone can help me step by step will be great thanks
  • 3 more comments
  • plarx7 Apr 17, 2009
    hi i ve read it all i think i should do 1 of these thing
    Cloning - Also known as mirroring. This display configuration is essentially one desktop space that is displayed on two monitors. What happens on one happens on the other.
    Stretch Desktop - This mode creates one large monitor with a resolution doubled in width. You move your mouse and windows across the screen from one to the other. This drawback here is you can't configure each monitor individually. This mode may not be possible using Windows Vista.
    Extend Desktop (most common) - Also known as Dual View. This mode creates two desktop spaces, and like stretching, allows you to move the mouse pointer and applications from one screen to the other. The advantage here is that each monitor can run at different resolutions.
    BUT how to do it though? im really dump with the computer sorry :-( step by step instruction will be appreciate
    thx u for that .i think i did extend my second mornitor and after i click ok i suppose to have two mornitor up on laptop screen but i have my first mornitor on my laptop screen and second mornitor on projector screen.but i dont know how to controland bring all stuff from mornitor 1 to mornitor 2 .i.hope u understand what i mean.
    hi thx for your recommending ,i ve been try to search through internet website in nz but i couldnt find any .is there any other way to fix it.
    thx u very much
    hi i ve been trying to connect projector to my laptop (acer travelmate 2420) . i did extend my second mornitor and after i click ok i suppose to have two mornitor up on laptop screen but i have my first mornitor on my laptop screen and second mornitor on projector screen.but i dont know how to control and bring all stuff from mornitor 1 to mornitor 2 .
    also i cant buy usb to DVI cable anywhere .anything else i can do?
    thank you for owesome help and super clear explaination .really help me a lot
  • 326 Answers
Hello. It seems that you have extended the desktop, when you only wanted it to display what was currently displayed on your laptop screen it self. You have two options from windows.
Method 1
You can leave everything set up, and simply click on the title bar, blue portion of open windows, and drag them across the screen as if you were dragging something physically from one side of the screen to the other, the window will continue past the right edge (by default) of the screen and onto your other screen, in this case, the projector. You can open the display properties, Right click desktop > Properties > Settings: and move the white boxes around to make you more comfortable if you would rather drag a window to the left instead of the right, just left-click and drag the 2 box to the left of 1.
That would allow for the least headaches given it is already working for you.
Method 2:
However, there is another option to try, which would be to select Monitor 2 as your primary display. in the same location as eariler, left click on Montior 2 and notice the two check boxes on the middle right. When "Extend my Windows desktop to this monitor" is checked you have an additional option "Use this device as my primary monitor. when you click this depending on which advanced options your manufacture has available, one of two things will happen.
Your projector will now show your desktop when your icons as if it were your laptop screen, and your laptop screen will show a blank desktop area in which you could drag windows over to as mentioned before
OR
Both the laptop screen AND the projector will display the same image.
It is my humble suggestion that you become comfortable left-clicking the title bar of windows and dragging them across the screen, to reduce the amount of hassles in getting method two fine tuned.
Remember that a window can not be dragged if it is Maximized, that is it takes up the entire screen. You must first click the restore button (The button resembling two squares ontop of one another between the Minimize "_" button and the Close "X" button) and then you can freely click and drag windows.
Rember also that the direction in which to drag windows depends on what you see in the Display Properties Settings Tab. Those two white boxes with numbers indicate physical placement of the monitors or "displays" If you are looking at your laptop, with the back of your projector parrallel to your laptop, facing you and it is on the left side of the laptop, you can not drag a window to the left of your laptop screen and have it go to the projector unless you have your monitor positions set up that way in the Settings. For that example, due to the left positon of the laptop, and making it more subconciously simple to use, you would need to left-click and drag box 2 to the left of box one.
Remember that right is default. So you dont have to change anything as long as you remember regardless of where the projector is physically in relation to the laptop, drag your window off the screen to the right.
Also, make sure to take care of the resolution settings for your projector in that box as well, once your comfortable moving windows around, left-click box 2 and adjust the slider for optimal quality.
Let us know if you need anything else.
Posted on Apr 17, 2009
  • NitrusInc
    NitrusInc Apr 17, 2009
    I just wanted to let you know of a common issue when working with 2 displays. If you run into a situation where your unable to continue doing anything after a command it is possible that a dialog box has popped up on the other screen, or even sometimes between the screens. Take care to address the "start bar" at the bottom for any blinking tasks that may occur if your stuck and receiving an exclamation sound when trying to continue.
    It is also important to note that any windows you maximize or close on your 2nd display will generally remember their positon. To combat any issues that may occur from this, always restore (the two squares between minimize and close) first and drag it back to your "primary", or the monitor that displays your start button and desktop icons, before closing
    So in short:
    Watch for dialog box's or blinking tasks on the bottom if your stuck after a command.
    Always close windows on your primary monitor.
    Hope these tips help save you some trouble in the future
  • 10,515 Answers
Hi plarx7,
 That's a fault in settings.
 Check one of the forums below...Check the answer........and make sure you have followed the same settings...
http://www.techlore.com/blog/entry/23182/Using-a-Projector-to-Display-Your-Laptop-or-Computer/
If the problem still remains, let me know.
Thanks for using Fixya.
Do rate the solution.
  • 1 more comment
  • taran_2005
    taran_2005 Apr 17, 2009
    I would be offline now.
     wait for few hours..You would receive a solution with explained steps.
    Thanks.
  • taran_2005
      The trick I use for connecting 2 external monitors to my own laptop is to connect one to the external video port on my laptop and a second monitor gets connected to a DisplayLink adapter. The adapter connects via USB allowing you to extend your desktop to another screen. They are sold under a variety of brand names which makes the adapters a little tricky to track down, but a quick search of eBay for USB to DVI adaptor  turns up several options that are basically the same thing under several different names. DisplayLink also links to several online stores, although they do a lousy job of labeling which country each store serves.
    How to connect laptop to a projector :-
    Check video :0
    http://www.ehow.com/video_4871725_hook-u...
    Now, to control stuff....
    Configuring LAPTOP:
    1. Go to Control Panel -> Network connections
    2. Right-click on Wireless network connection and select Properties
    3. Select Advanced tab and put a thick in the box "Allow other network users to connect to this computer's Internet connection"
    (You can also put a thick in the other box if you wish)
    4. Confirm with the OK button and find yourself back in the Network connections window
    5. Next, in Network connections Right-click on your LAN adapter, under General tab select Internet protocol (TCP/IP) and click Properties
    6. Assign IP manually (192.168.0.1 - this is also the default if you use Network ...
    Thanks.
    Any further help, let me know.
  • taran_2005
    This seems to be an issue of extend desktop.
     Let me offer you one more fix,
    You need to have a video card with 2 video connectors....
    Windows XP
      1. Click the Start button and choose Settings -> Control Panel.
      2. In the Control Panel, double-click Display to open the Display Properties dialog box and click the Settings tab.
      3. Click the monitor icon representing the monitor you are adding to your system.
      4. Place a check mark in the Extend My Windows Desktop Onto This Monitor check box.
      5. Click OK.
    Windows Vista
      1. Click the Start button and choose Control Panel.
      2. Click Personalize, then click Display Settings.
      4. Place a check mark in the Extend The Desktop Onto This Monitor check box.
      5. Click OK.
    Try and let me know.
No backlight on laptop LCD screen
The only solution I can think of is that your 40pin cable from the motherboard to the screen is damaged. They do fail just through use (opening and closing the laptop lid can put strain on the cable) Try replacing this cable.
Leon
Feb 09, 2013 | Sony VAIO Computers & Internet
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
I can see my background but cannot see anything else
The Fn+F8 in some laptops or Fn+ KEYS WHICH HAS MONITOR ICON OVER FUNCTION KEY) command tyically runs through 3 modes: Extend desktop, Laptop only, Projector only.
Mirroring displays (meaning you see the exact same thing on both screens) is not always on option on a PC; the ability to do that is dependent on the graphics card and drivers in the laptop.
Not seeing the exact same thing on both screens is often the preferred way, but when you don't see all your desktop icons it can be a bit confusing.
The trick here is that when you want something to show on the projector, you grab the window you're working with and drag it over to the other monitor. Why this is preferred is because you can be showing a powerpoint presentation on the projector, while you have a script or notes open in Word on your laptop display to read from. You see, you don't see anything but the desktop background on the projector because you haven't moved anything over there yet.
Your laptop is in extended mode, try changing to Laptop mode, should solve your problem or try dragging the required file to that monitor as said above
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 24, 2009 | Acer Office Equipment & Supplies
Cannot get the Projector to see my emachines D620 Laptop screen. Press FN+F^ my computer screen goes dark but nothing shows at the projector tested the projector worked fine with other laptop
To check if the external video port on the laptop by connecting an external monitor to the laptop and see if it works. If it does work then the video port is OK and the only thing I can think of is :-
What is the highest resolution that the projector can display?
Is the video resolution on the laptop set higher than the projector's maximum resolution, if so reduce the screen resolution on the laptop.
Aug 14, 2009 | eMachines eMD620-5133 Notebook
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
No display, nothing on screen
Try to hit the Fn+F8 button at the same time 5 or 6 times. This is what is used to turn off your LCD to plug it to a projector or to use a different screen. If that does not work then try to find a desktop monitor and plug it into the 9-pin slot on your laptop. Again hit the FN+F8 buttons again, if the display shows up on the desktop screen then you know that something has burnt out your LCD screen on your laptop.
Dec 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Displays desktop background but nothing else
I discovered that my laptop supports two monitors and the projector was acting as monitor #2. By changing the priority of the monitors I have got the information I need on the screen, but now not on the laptop. However, I can work the two from the screen and that will suffice for the moment, until I can find a way of getting the information on both!
Sep 05, 2008 | Philips bSure SV1 Multimedia Projector
Problem with mitsubishi sl4u projector
make your pc or laptop start first and then the projector.
Mar 26, 2007 | Mitsubishi SL4SU ColorView Multimedia...
Sony VPL-CX6 Multimedia Projector Logo
100 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
