Question about RCA F32672SB 32" TV
My computer won't turn on
If i turn on my pc. it starts but sooner it shutdowns and turns on again.
    President:
  • 2,961 Answers
You need to access the motherboard and look for the disk shaped cmos battery (CR2032)and put in a new one as when the battery gets too flat it will cause a continual boot up cycle. If the battery is ok, then you will need to select Del or F2 on boot up to get into safe mode and select last known good configuration and hit enter for a reboot. if you have changed any hardware, then you need to repair windows using your XP cd
Posted on Sep 16, 2007
SOURCE:
My HP laptop completely shutdown on restart, But not on shutdown , have to press power button to turn it off
Adjust your power settings (you did not mention what operating system you have) Do a search in your RUN box for "Power Settings" Here you can chose the way you want things to run on your computer.
Aug 21, 2014 | HP Pavilion Computers & Internet
Desktop won't make a sound when I turn it on
Check to make sure the power switch on your surge protector hasn't been reset - also check the connection at the back of the computer -
Jan 15, 2013 | Systemax Venture PC Desktop
Computer will not come on after shutdown. may take 12 15 hour
I would look inside at the power supply IF you can get to that for puffed up caps---if found you can either replace them (seen some with several bad) or look for a generic replacement power supply.
Usually here it will begin by being hard to turn on at first but once on will operate--sooner or later it will not come on at all.
Apr 15, 2012 | eMachines W Computers & Internet
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Turns off without warning, will not start again unless turned off by holding in the button
Is the problem Consistent? By this i mean does it occur at a set amount of time into its use?
This sounds like it could be an overheating issue. Check to see if it turns off sooner when doing something CPU intensive, and if it turns off even sooner after you turn it on again. Try cooling the laptop somehow.
Mar 21, 2011 | Toshiba Qosmio X500S1801 (PQX33U01H01M) PC...
WidwsVista hw to exit from safe mode
If your computer always starts to safe mode, go through the following steps:
· press <windows kwy> + <R>
· type MSCONFIG then press enter. This will open the System Configuration window.
· click on the BOOT tab and make sure nothing is checked/ticked in all the boxes you see.
· click OK button
· check/tick the box that says "Don't show this message again..."
· press RESTART COMPUTER button.
Your computer should boot to normal mode.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Computers & Internet
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Oct 02, 2007 | IBM ThinkPad A21m 2628 Notebook
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
