Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
FUSE BLOWS WHEN BLADES ARE ENGAGED CRAFTSMAN MODEL # 917.27686
WHEN i ENGAGE THE BLADES THE FUSE BLOWS
  • 62 Answers
Most probably you have a wire shorting to the frame of your mower.
Trace (follow) the wires from the switch, checking for any frayed, burned, or bare wires.
Repair as needed.
Posted on Apr 17, 2009
I have a husqvarna loyth20f42y riding mower it wasn't starting replaced the solenoid and ignition switch. now it starts but every time I engage the blades it blows the fuse
Because it blows when the blades are engaged, it is probably the PTO switch or electric clutch. You can check both quickly with a multi-meter. The clutch should ohm out at 2-5 ohms.
Oct 30, 2016 | Husqvarna Garden
Does model # 917.276021 have a mower lock out on the transmission
The PTO when engaged draws a lot of power from the battery. Check the battery for proper voltage. If your battery is low or say 1/2 charge, it will never engage the blades and will die every time you try to engage the blades.
Aug 04, 2014 | Craftsman Garden
Craftsman 19.5hp 42 in deck lawn tractor blows 20amp fuse when blades are engaged replaced fuse happened again
Inspect the wiring safety switch that is at the bottom of the lever.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Aug 12, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 42'' mower, blades won't engage
You deffinately have a loose wire or connection coming off that switch,youll have to investigate to find out where it is.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
337 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
