Question about Dryers
Whirlpool gas dryer model number lgr6848aw0 is working but not heating. Please advise you opinon on what the problem might be. Thank you in advance for your assistance in this matter.
  • 659 Answers
It is probably the limit switch which is located near the burner. It has 2 wires that terminate on a small disk about the size of a dime. There is a button located in the middle. Depress the button firmly. This should take care of it unless it is the gas valve.
Posted on Apr 17, 2009
No heat from dryer
Is this a gas or electric dryer? Please post the model number so I can look it up for you and give you a more direct answer.
Sep 06, 2012 | Whirlpool Dryers
Model LGQ88800JQ0 Serial number MK1801241 It is not drying. I check the thermal fuse and it has continuity. Could you please help. email: pachy92@hotmail.com phone 262.521.9369 Francisco Martinez
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 18, 2011 | Whirlpool LGQ9857L Gas Dryer
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
My dryer will not heat up. model number LE9480XWW1 stock number LE9480W
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Whirlpool Dryers
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Whirlpool GEQ9858J Dryer
My whirlpool dryer tumbles and runs but has no heat. Its a gas dryer and tge model number is LGR3624EQ1
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 12, 2010 | Dryers
Dryer spins but does not dry brand is whirlpool model #LE7680XSW2 can you tell by model number what the capacity is. Thank you
heatman101
May 11, 2010 | Whirlpool LER4634J Electric Dryer
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
May 27, 2009 | Whirlpool LGR8648 Gas Dryer
Whirlpool calypso gas dryer ggw9868kq0 No lights on control panel dryer drum light works Brian
Hi please ..helppppppppp
whirlpool model number LGR4634 PQ1 got heat for couple time,when its first start,but,later you can the igniter tried to start,but no flame after that.
please.help ..please..thanks an advance
Jul 02, 2008 | Dryers
Dryers Logo
138 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
