Question about Compaq Presario M2000 Notebook
My acer aspire will not turn on it just has a orange light blinkin please help
  • 700 Answers
Try to charge it first for sometime then power it up. If it doesn't help try to clean your RAM card with soft eraser, only its edge connector. But disconnect its battery first and its power suppy.
hope it helps
Posted on Apr 17, 2009
When i press the power button on my acer aspire one zg8 the green light does not come on and the computer does not start but the orange battery light slowly blinks a couple of times. This happens with the...
Please remove the battery and turn on laptop on AC Power adapter. If the laptop is started and working fine then the battery is having problem. Otherwise check the DC voltage of the adapter in dc with multimeter. Check the adapter is good or not.
Hope this helps.
Jul 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one notebook won't boot up...battery light flashing and goes orange when steady...help? -please respond with 'Private' in subject header of email, thanks.
As you describe the situation, it sounds similar to laptops that suffer from the Maxim chip failure. This is a motherboard defect that is caused by a loose Maxim 1987 or Maxim 1532 chip that causes the laptop not to work at all. Please head over to this Maxim 1987 chip problem and motherboard repair manual for details. If your laptop matches the listed symptoms then you can either get a new motherobard or use the repair manual to do the repair yourself, or ask somebody else to follow the instructions and do the repair.
If you found this helpful and informative please give this post a Thumbs Up. Thank you.
Jan 18, 2011 | Acer Aspire One PC Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
Acer aspire 1500 will not turn on
Try removing the battery and running the power directly through the power outlet. HP laptop dv6000 has the same problem.
Nov 06, 2009 | Acer Aspire 5100 Notebook
Flashing orange and yellow lights
Most likely your battery is dead.
If you are worried about your HD , the best thing to do would be to power it off.
Remove the battery and see if it will boot on the AC adapter.
If it boots , just get a new battery.
If not you have a motherboard issue and need to call Acer if it is under warranty.
Apr 22, 2009 | Acer Aspire 5003WLMi Notebook
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
NOT TURNING ON LATOP ACER ASPIRE 1410
ya im having the same problem. please help!
Jan 20, 2008 | Acer Aspire 5100 Notebook
Flashing Orange Light
the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
Aug 04, 2007 | Acer Aspire 3003LCi Notebook
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
