Question about Hoover Powermax S3530 Bagged Canister Vacuum
Hoover powermax s3530 spitting out dust
My hoover cannister vac is no longer working properly- it spits out dirt/dust instead of picking it up! I don't know if this is fixable- changing the bag does not help. Any ideas on how to fix it would be great!
  • 116 Answers
Recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Posted on Apr 17, 2009
My vacuum no longer has suction to pick up dirt. In fact it spits what it picks up back out now..
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Jul 21, 2010 | Vacuums
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 | Vacuums
New vac no instuction manual . i need to vaccumn
No you do not need the filter to pick up glass. If you are vacuuming up dust/dirt then use the filter.
Jan 22, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Gets hot picks up dirt then it falls out again
Check the throat of the vac itself where air and dirt passes through to the back and into the intake. The heat would indicate you have a loss of air flow though to the chamber.. try dropping a coin backward through from above down to the bottom of the vac. his will help indicate whee a blockage is.
Sep 26, 2009 | Eureka Capture Upright Vacuum Vacuum
S3530 belt part number
your machine should have a tag with the model #, web address, toll free #, and possibly the part # for the belt. You can either go to the website and enter the model#, or call 800# and get the part number
Aug 28, 2009 | Hoover Powermax S3530 Bagged Canister...
Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Aug 23, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Vacuum is spitting dirt and debris out the back--what can I do?
the first thing you should do is clean out the container then check the filter if it looks dirty with a lot of dust it probably needs replacing.
check the hoes for dirt that might stick up.if the problem continues it needs a service.
Jul 30, 2009 | Hoover U5753-900 WindTunnel Bagless...
While vacuuming, debris spits out the back.
that's normal. try lowering the heght adjustment
Mar 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
My hoover vacuum spits out dirt particles as I vacuum!
the vacuum is clogged somewhere the brush roller is just kicking stuff around, as it cant get into the suction port
Aug 25, 2008 | Hoover S3614 Vacuum
Hoover Powermax S3530 Bagged Canister Vacuum Logo
392 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
