Question about Hitachi CM811 Plus 21 in. CRT Monitor
Cant find drivers
Who cn help me to find drivers for this monitor. When i look now i see everything twice. And i have nog driver from the monitor, and maby its my graphiccard its now 128k i have vista. who can help me. grzz Blekenone
0 characters
1 Points
Samsung SyncMaster 713BM
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Mar 27, 2010 | Samsung SyncMaster 713BM 17" LCD Monitor
Screen images are too tall and thin.
Try to Get the New updated driver from Nvida web
Nov 30, 2009 | Dell E173FP 17" LCD Monitor
Blurry screen
check your cable VGA or DVI - reboot - if not work, uninstall your drivers and reinstall them
Sep 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
I cant get the right resolution on my Norcent monitor
If the company said you need a driver, how come the monitor don't come with a CD to install the Driver? How come they did not point out how you can get the Driver? Look in Device Manager under "Monitors". Does it say "Plug and Play"? If so, you don't need any monitor driver. Try adjusting the resolution on the desktop also, right click in desktop, properties, settings, adjust the slider...
Aug 12, 2009 | Norcent Technologies LM-962 19" LCD...
Can not config the size
if the screen is big, try to change the screen resolution, or install the video driver from the manufacturer drivers disk that you would have,,,
refer to help and support in your computer for guidance on how to reduce the screen resolution,,,
click on start >>>> help and support, then on the search box type how to change the screen resolution
2. how to install the video driver
you will have step by step instructions, and you could get it resolved,
follow those steps clearly
Feb 14, 2009 | Acer AL1912 19" LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
No Signal message displaying after screen goes black
Try loading drivers for the LCD monitor.Right click empty part of desktop>>Properties>> settings It should show monitor name instead of plug and play monitor on ---- Video board.Go to Advanced>monitor>driver on this screen.
May 06, 2008 | Acer AL2017 20" LCD Monitor
Everything has gone vertical
What type of computer? which model? and which screen? is it a laptop or a tablet.
Check your screen settings if its a seperate screen there may be a button on the bezel for changing the layout.
Also the orientation can be changed in most video drivers. set the screen on its side so you can see and right click on your desktop and manuver to "properties" goto the last tab then click advanced. search around in there for orientation, sorry but exact step by step varies from there depending on which driver you are using.
if you try something in that menu that doesnt work, just cancel out or hit escape.
May 02, 2008 | Dell E173FP 17" LCD Monitor
Software app HP Director won't run
try to update the driver of your acer lcd and removed the driver of your old lcd.
Jan 01, 2008 | Acer AL1716 17" LCD Monitor
540n screen is bright white
Due to it is new monitor the best way to solve problem is to take monitor back to seller and afterclaim it. Malfunction is inside monitor and you are not able to fix it.
Good luck
Dec 11, 2006 | Samsung SyncMaster 152N 15" LCD Monitor
Hitachi CM811 Plus 21 in. CRT Monitor Logo
22 people viewed this question
Top Hitachi Computer Monitors Experts
james allen
james allen
Are you a Hitachi Computer Monitor Expert? Answer questions, earn points and help others
