Question about Kenwood Excelon DDX-7015 Car DVD Player
The unit will not turn back on. i turned it off for one day and now it won't turn back on. it gets power and i checked all of the fuses. it worked perfectly until now.
    Problem Solver:
  • 5 Answers
Can you hear it power up?
Posted on Jul 05, 2009
  • geomendez Jan 08, 2011
    It was open and closing to put cd in, but nothing would happen. Blank screen only. I could unload the disk too. A few days later now the front won't even come down. HELP!
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
2005 Jetta Radio
It could be the radio fuse in the unit it self, also check the cigarette lighter fuse as they are normally on the same fuse link!
Jun 26, 2013 | Car Audio & Video
Back windshield wiper won't turn on
The rear wiper has a dedicated fuse. It's the 10A R/WIPER fuse in the relay block. This supplies power to the rear wiper and washer switch and the rear wiper control unit. That unit also gets power from the 20A AUDIO (!) fuse in the engine room fuse box. If the fuses are OK, the ignition switch is in the ON position, and the rear wiper and washer switch is turned on the rear wiper should work. If not check all the components described to find where the loss of power is occurring
Nov 15, 2012 | 2005 Kia Sorento
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
We have a Coleman Evcon air conditioning unit model brcs036b and we cannot get it to turn on nor can we find if there are any fuses. the heater works but the actual fan motor for the air conditioner...
Check your stat. is it set properly on cooling, and low enough to turn the unit on, with power on and the stat calling for cooling you should at least get the fan and the out door to kick on, if not your stat or the transformer could be bad. there is a reset on the transf. on some of the unit that could be tripped
Jul 04, 2011 | Heating & Cooling
06 hyundai monsoon radio won,t turn on.
Just got an update from a dealer that might work...take the head unit out and unplug the power for about 30 sec. plug back in and the unit should basically reset itself. If that doesn't work I'm out of guesses.
Dec 27, 2008 | 2006 Hyundai Santa Fe
Magellan 760
sounds like your power dock is the culprit, not the internals, you can purchase one from circuit city or tigerdirect.
Sep 19, 2007 | Magellan Roadmate 760 GPS Receiver
Central air conditioner doesn't turn on... Any suggestions?
If the compressor turns off and won?t come back on during a very hot day, the unit may have built up a high "head" pressure and the high-pressure limit switch may have tripped. This is usually located right inside the access panel on the compressor unit. Simply push the button to return it to operation. If your central air conditioner doesn't go on automatically: 1) Be sure the thermostat is set to "cool" and set below room temperature. 2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem here, reset the breaker or replace the fuse. 3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, mounted on the outdoor unit, hasn't been shut off. Also be sure the 240-volt disconnect next to the compressor (in a metal box, usually mounted on the house wall) hasn't been shut off. 4) Turn off the power to the air conditioner and check the thermostat. 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. 6) Turn the power back on. 7) Holding the wire by its insulation, touch the bare end to the R terminal and hold it there for about 2 minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a service technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Kenwood Excelon DDX-7015 Car DVD Player Logo
178 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
