Question about Emerson EWL3706 37 in. LCD Television
Both volumn and channel buttons will not arrow down
Volumn and channel button will not go down. You can arrow up on both but not down.
    Novelist:
  • 159 Answers
There is a trace broken in the front panel circuit board (where the switches are installed) and the line is open to the microcontroller. this solution can be easy in the workshop. Specially because two other switches work.
Posted on Apr 17, 2009
Button to scan in channels
The CT-90326 remote was included with several Toshiba televisions, including the 42HL800A. You can't directly scan for channels with a single button on the remote. First make sure that the TV is set to the TV input. (Use the Input button on the remote (top left) or the TV (lowest button on the left side as you face the screen).) Next press Menu (the second lowest button on the TV or the button at the lower left of the Left arrow button). Use the Left or Right arrows to select Setup (with the gear icon) and press OK. Use the Up/Down arrows to select Auto-Tuning and press OK. Use the Up/Down arrows to reach the line to select the type of channels to search for a signal. Then use the Left/Right arrows to select Digital channels, Analog channels or both. Go down another line to set the bandwidth of your broadcasts. Again use the Left/Right arrows to select the correct one. Go down one more line to Start Scan and press OK.
These details are in the manual for your TV. The manual for the 42HL800A is available from Toshiba's product support download page: http://www.mytoshiba.com.au/support/televisions/led-backlit-tv/hl800a/42hl800a/download . The direct link to the manual is http://www.mytoshiba.com.au/file/download/resource/file/19610/toshiba_32av80032%2040lv80026%2032el80032%2042hl800_om%20(au).pdf .
I hope this helps.
Oct 02, 2016 | Toshiba CT-90326 Remote Control
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
How do you run channel auto scam
HI,
To auto preset channels do the following procedure.
1. Press the SETUP button on the remote.
2. Using UP/DOWN arrow Select CHANNEL SET UP and press the RIGHT arrow to enter to channel preset
3. Using UP/DOWN arrow select AUTO PRESET and press the RIGHT arrow to start the auto scan.
Wait till The tuner scans and memorizes all the active channels in your area.
ok
Sep 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
How can I place tv on channel 3 with out remote?
Near the switch ON/OFF button there must others that control the volume and the channels. Usually the channel switching buttons have an arrow pointing Up and another pointing down. The two button may be the up end and down end of a bigger button. That is the general idea. But you should examine the TV around the control buttons looking foe some inscriptions that will help you identify which is which.
Turn your TV on. Identify the volume control buttons.
By pressing on the button (or the button end) with an UpArrow you ascend the channels. Pressing the button with the down arrow decreases the channel number.
Jan 30, 2010 | Emerson Televison & Video
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
We cannot tune our Wega TV
Here's the procedure:
  1. Press MENU.
  2. Press LEFT ARROW to highlight Channel Menu.
  3. Press DOWN ARROW to highlight Cable. Press CENTER BUTTON to select.
  4. Press DOWN or UP ARROW to highlight On or Off according to how you connected your TV. Press CENTER BUTTON to select.
  5. Press DOWN ARROW to highlight Auto Program. Press CENTER BUTTON to search for channels.
  6. After Auto Program finishes, press MENU to exit.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Emerson EWL3706 37 in. LCD Television Logo
22 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
