Question about Ricoh Office Equipment & Supplies
Need to find part #'s, parts, and service manual for drum unit,etc
I have a Savin 8025, I need to find out which drum unit, upper and lower drum roller it takes and replace them.
I have Ricoh part numbers for the Aficio 3025, which is the EXACT same machine, using the EXACT same parts. And I assume you mean upper and lower "fuser" rollers.
Photoconductor unit P/N B205 0151
Hot Roller P/N AE01 1103
Pressure roller P/N AE02 0161
Posted on Apr 17, 2009
Drum Replacement
Its more involved than you think, you should change the drum blade and charge roll also, developer need replacement at 60K also (in the same unit) all fixed for about 350 from your service guy
Apr 11, 2014 | Savin 2515 Drum Only Genuine
Savin copier drum cleaning blade for 8045
Service call is cheaper than you damaging the drum
Dec 19, 2012 | Savin Office Equipment & Supplies
MY SAVIN 4700WD WIDE FORMAP COPIER/PRINTER/SCANNER MACHINE COMES UP WITH AN ERROR CODE "SC35303". tHE ERROR CODE ISSUE HAS PROGRESSIVLY COME UP MORE OFTEN. CAN I DO ANYTHING OR DO I NEED A...
The error code is from the image density sensor, it may be dirty or not able to read the drum surface correctly. If it hasn't been serviced in a while a preventive maintenance will be needed. What is the meter reading on the unit at this time? Hope this helps.
Jul 12, 2011 | Savin Office Equipment & Supplies
WASTE TONER BOTTLE REPLACEMENT FOR SAVIN 2400WDP
Lift the upper section and on the right side take off lower right cover. -Carl
Jun 08, 2010 | Savin Office Equipment & Supplies
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Prep to ship Savin 4035 without damage
The main thing you need to do, is to remove the toner bottle assembly, drum unit and developer unit. There is a small black stopper you'll see once you pull out the toner bottle unit. Remove the stopper and the tray holding the bottle will slide out of the machine. The drum unit has a thumb latch on top of the unit and all you have to do is open the right side door, release the lever and remove the drum unit. DO NOT TOUCH THE DRUM! The developer unit is below the drum unit. There is one screw holding a silver piece of metal which secures the unit in place. Loose the screw and fold it down to the left and then remove the developer unit. These steps will keep toner and developer from spilling out into the machine. Good luck.
Jun 25, 2009 | Office Equipment & Supplies
Replace drum cleaning blade
take the toner hopper off take dev unit out lower handle on umber one unit remove screw in drum pin remove primary charge assy remove screw lower right of drum frame remove screw upper left frame un plug connectors unit slides out
Oct 31, 2008 | Canon NP 6545 Copier
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
178 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
