Question about Craftsman Gas Mini - Tiller/Edger
Don't know how to remove the clutch
I have a Craftsman mini tiller and I do not know how to remove the clutch
bbreton
  • 437 Answers
SOURCE: What type of oil goes in my 4 cycle 26cc mini
regular 30whd just like your lawn mower
Good Day.
Posted on Oct 26, 2009
backwoodsctr
  • 169 Answers
SOURCE: what is the hp of a Craftsman 4-Cycle Mini Tiller
Depending on model the hp is 1.4 hp
Posted on Nov 21, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I need to know the plug gap on a 31.5cc Craftsman
Set you spark plug gap to twenty five thousands, or the width/thickness of a match book cover if you have no gauge.
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on Jun 02, 2010
  • 11 Answers
SOURCE: craftsman mini tiller
Our MiniTiller died so we tore it apart and cleaned it. It still did not work so we tore it apart and examined it more thoroughly and then found the carburetor to be in a horde mess. We don’t want to repair it ourselves so knowing where to buy a new one or to know where to find a repairman would help.
http://www.craft-ideas.org/
bbap
  • 71 Answers
SOURCE: I have a Model 29270 REV B00 Craftsman 4 cycle
Craftsman part numbers will help on this search. Typically 3 digits separated by a '.' such as 345.45687
If you can find these, please re-post the question. :)
Posted on Sep 25, 2010
How do you change the primer bulb in a craftsman mini tiller?
some primer bulbs come as an assembly and have two clips that snap into the housing others are bolted in with 2 screws if so remove the screws and make sure to take what is left of bulb to match up the new one
Oct 15, 2012 | Craftsman 2-Cycle Mini Tiller
Craftsman mini tiller runs great for a few minutes then revs up a little and then dies. Restarts after a few minutes and then repeats over and over.
Fuel starvation, try slacken the filler cap to rule out a blocked tank vent, if no better replace the fuel filter in the tank, if no better you will have ti remove the carb and clean the filer under the pump diaphram.
May 13, 2012 | Craftsman Gas Mini - Tiller/Edger
I own a 2 cycle mini tiller craftsman and I need a manual for it. I want to tune up tiller it's blowing smoke.
Manuals for many Craftsman tools are available here: http://www.managemylife.com/mmh/owner_manuals . Lots of tillers are listed just by searching for Craftsman tiller. If you can find the model number (usually on a plaque on the housing of the tiller), you can narrow down the list greatly.
I hope this helps.
Mar 31, 2011 | Mtd Craftsman 4Cycle Mini Tiller
I have a Model 29270 REV B00 Craftsman 4 cycle mini-tiller. Can't find a spark plug or air filter. Appreciate some direction.
Sep 25, 2010 | Craftsman Gas Mini - Tiller/Edger
Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
Craftsman mini tiller. Are you selling this unit, giving it away or what. Your information is somewhat meager to say the least.
May 28, 2010 | Craftsman Gas Mini - Tiller/Edger
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Apr 06, 2010 | Honda 25cc 4-cycle Mini Tiller
Craftsman Gas Mini - Tiller/Edger Logo
398 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
