Question about Uniden Cordless Phone
Need replacement batteries
Need battery for GE cordless headset telephone model 2-9918A. This is not a new product
  • 89 Answers
Are you sure the model isn't Model 2-9910A? In any case check out, www.radioshack.com or www.batteriesplus.com. They will surely have it.
Posted on Apr 17, 2009
How do I access the battery in the cordless handset
GE 30524EE2 DECT 6.0 Corded/Cordless
Don, Battery replacement is on page 13 on the first link. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE 30524EE4 User Manual Battery Installation
http://www.videofon.rs/ge/pdf/30524.pdf
http://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf
Apr 05, 2016 | GE 30524EE2 DECT 6.0 Corded/Cordless...
Lost manual
GE branded Consumer Electronics are now sold by Thomson Consumer Electronics, Inc. Please call Thomson at 1-800-447-1700 for electronics product support.
Dec 02, 2007 | GE 21008GE2 Dual-Handset Cordless...
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
I have a GE cordless phone and answering machine, model 27995GE1-A, and finally found where to get a new battery for it. When it is fully charged, is it better to leave on the charger or off, when not in...
Newer phones don't have the battery problems of old. Just to be safe I would leave the phone off the charger after the first call. Put it on the charger when you go to bed.
Jun 29, 2009 | Thomson GE Cordless Telephone 27995GE1
Need battery for cordless headset phone - model 2-9918A
I could not find the battery for your phone. But you may click this link and I hope this would help you:
http://www.amazon.com/s/qid=1239954169/ref=sr_gnr_fkmr?ie=UTF8&node=&search-alias=aps&field-keywords=GE%20Battery
I believe that any battery that has the same voltage output and same connector would work with your phone.
Apr 17, 2009 | Uniden Cordless Phone
I need a battery
http://www.needbattery.com/searchView/3-6v-600-mAh-Cordless-Phone-Battery.html?type=cf&equiv=Bell%20Equipment%20GP60AAAH3BML&productCode=BCO1051&internal=0&refx=G00GX&gclid=CMCX5cO1xJkCFeRM5QodbQMqKg
You can check the list for the model# of you phone, its easier to search with the model# of phone then bat #
Mar 28, 2009 | BellSouth GH5831BK Cordless Telephone
Replacement Battery for GE 27933GE2
3SN-AA60-S-J1
check out the lenmar.com site. they sell a replacement NiCad battery for that phone. i'm in the process of replacing mine.
3.6V, 600mAh
Jan 20, 2008 | GE 27933GE2 Cordless Phone
GE 5.8 ghz cordless phone
Get another telephone and connect the telephone cord from your cordless phone to it. If it works, then you know the problem is with your GE cordless phone. If it doesn't, try replacing the telephone cord. If still no good, call your telephone company.
Nov 05, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
65 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
