Question about Whirlpool WTW6600SW Top Load
Whirlpool Cabrio Mdl WTW6600SW
Flashing code F50. Also leaking from an as yet unidentified source. 13 months old. Sorry about theat 12 month warranty - ha, ha.
    President:
  • 1,314 Answers
Some times well a lot of times if you call cust assistance and your that close to your warranty they will comp the call but if you didn't send in your warranty card and haven't had a service call then they don't know when you bought it be sure to get cust assistance and not cust service f 50 is the code for a stalled motor see if your basket spins freely
Posted on Jan 27, 2008
SOURCE:
Code f 50 on cabrio WTW6600SW2 what is the most likley cause
Silverdragon posted the following yesterday about this issue...
http://www.fixya.com/support/t4267679-wtw6600sw2_cabrio_giving_me_f50_code
F50 - motor stalled The biggest problem with this machine is the rps sensor. If you pull the motor cover you can get to the rps. Then take the rps on and off about 5 times to remove a factory coating that keeps it from making the contact that it needs. For some reason the machine will work fine for several months after purchase before this occurs. After you do this it works fine. F50 f51 f70 codes
Mar 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600sw2, cabrio giving me the F50 code. Any ideas as to what that means?
Mar 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f50
It has a faulty control board. sorry but this a bad part from the factory. There is class action lawsuit against whirlpool about it. Call and complain and then maybe they will pay to fix it.
Nov 18, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio code F50
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Nov 07, 2008 | Whirlpool WTW6600SW Top Load
Water valve P/N 8577407 failed after 13 months
If you ever buy anything from Sears, always keep a warranty,we do and had to use it alot.
Jun 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6600SB
its under warrenty call for service if you attempt to fix it it will void the warrenty
Dec 05, 2007 | Whirlpool WTW6600SW Top Load
Whirlpool WTW6600SW Top Load Logo
230 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
