Question about Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW
Averatec 22" all in one pc
When I turn the streaming video to full screen, the video stutters at noticeably rates. Is the monitor too big for it to stream properly? It works find at normal screen. Please help me fix this problem. Do I have to change resolution or anything? The graphic card I'm using is Geforce 8400M GS with 2gb ram. Thanks
  • jetk15 Apr 17, 2009
    Thank for the response. I did some more searches, and found this sitehttp://forum.notebookreview.com/showthre... which pretty much all you have to do is to disable the video accelerator.
  • 537 Answers
Your internet connection might be too slow or not enough bandwidth available. Are you doing this streaming from within a browser? If you are, try a different browser like Firefox or Google Chrome
Posted on Apr 17, 2009
How do I convert a Westinghouse 22" LCM-22w3 DVI/VGA LCD Monitor into an HDTV?
Dear Amy,
Normally, monitors do not have tuning electronics for capturing TV signals.
Therefore, consider the monitor as a "dumb" unit that only displays information coming from your computer. Also, this unit does not have a HDMI input, but only VGA.
So, you are fated to have this monitor connected to your computer, always.
Now, you may find good software that will "tune" the TV signals from streaming at the Internet and show whatever is being broadcast. The same way you can access YouTube and watch videos these TV tuners will get the streaming signals the TV stations send via Internet (not all do that) and watch the channel in your PC/monitor
Since I do not have additional information about the computer you use I cannot give you other ideas
I hope I have helped you.
May 18, 2014 | Westinghouse 22" LCM-22w3 DVI/VGA LCD...
I have an Averatec all in 1 D100 that the screen has lines all through it...I still get a picture but it has lines
Lines is a LCD cable or LCD problem, sometimes it can be video card. Try to check LCD cable soldering, check LCD cable, try to replace LCD, befor do it check your PC with other external monitor - if external monitor works fine then do it...
Nov 14, 2012 | Averatec D1002UHCE-1 All-In-One Intel...
How do I fit the desktop to the full screen of the monitor?
before you change your screen resolution, you should know first the dimension of your monitor..
this is the common screen resolution for 22 inch LCD monitor: 1600 x 1024 1920 x 1080 up to 3840 x 2400
Note: You can only use this resolution if your video card supports this given screen resolutions. You can set your resolution through configuring the display setup.
May 26, 2011 | Emprex LM2201 22" LCD Monitor
Hi guys! I badly need a help. hope someone can help me solve my prob in my averatec 6200 series. i just upgraded my OS from windows XP to windows 7. in my performance rating i always get a 1.0 rate bec of...
Hi, it does not matter which monitor the Notebook has, the ratings may change depending on the Hardware performance of the Notebook, Please make sure you have installed all the latest Drivers for Windows 7 OS. Usually the notebook manufacturer will release Drivers for Windows 7 OS in there Website. If you are using Windows XP Drivers for Windows 7 then the performance may vary.
Please check your Hardware Specification by downloading Speccy program from the below link:
http://www.piriform.com/speccy
Please follow the below steps to enable Hardware Acceleration.
1. Choose Start > Control Panel.
2. Double click Personalization and select Display Settings.
3. Click Advanced Settings.
4. Click Change Settings on the Troubleshooting tab.
5. Move the Hardware Acceleration slider to Full.
6. Click Apply and then click OK to accept the new setting and close the dialog box.
7. Click OK to close the Display Properties dialog box.
8. Restart Windows.
Apr 13, 2011 | Averatec 6200 Notebook
Screen wont light up.
Try testing the system on with an external monitor if it displays then the screen LCD is faulty and need to be replace with a new one.then the best thing is to get the screen been change .
rate this solution..
May 07, 2010 | Averatec 3200 Notebook
I have an averatec D1002UHCE-1 and for no reason the screen is not turning on. LEDs and Fans turn on but the screen does not show anything. What can i do?
Clarification - I have the same problem. Keep in mind that this is an All-in-one. There is no cable from PC to monitor. PC is built into the monitor. I suspect that the motherboard needs to be replaced, since even if it is the graphics adapter, it's on the motherboard...
Jan 26, 2010 | Averatec D1002UHCE-1 All-In-One Intel...
Averatec N1000 dark screen
yes what u need to do is that connect the external monitor with the laptop and if works fine with the external monitor then what u can try is that uninstall and reinstall the video driver and ten restart ur comuter and still if that doesnt work then replace the lcd screen...
Jan 25, 2009 | Averatec 1000 Notebook
Averatec 3150h monitor problems
this is the problem of display cable that gives display to the screen consult the technician near you
please rate this solution
Oct 16, 2008 | Averatec 3150H Notebook
Averatec screen does not light up
First, plug a external monitor and toggle the screen with ALT+F5. This will determine if the reason of the problem is hardware or software (drivers, configuration, etc).
If the image in the external monitor is correct you probably have a hardware problem with the LCD screen, inverter or cabling.
You can get the replacement parts here and change it yourself:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 12, 2008 | Averatec 6200 Notebook
Stuttering video stream - e.g. when downloading a clip on YouTube, it downloads ahead of the playtime, but the clip itself acts like a slideshow rather than videoplay. Im using windows XP 2002 SP2, on an...
I would fist try updating the memory to at a minimum 256MB. You might also try changing you display card an accelerated model. My guess would be you are currently sharing memory with an onboard display card. Not good for Video streaming!
Mar 07, 2008 | Computers & Internet
Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW Logo
306 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
