Question about Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3
Generac control wires
The cable that came with the generac has 4 control wires in it. The connection block in the generator and the transfer switch has 6, am I missing something or do 2 wires not have to be connected?
  • aarlank
    aarlank Mar 13, 2012
    the other two are probably for the battery charger circuit
  • 33 Answers
Older model Generac only haver 4 control wires:
N1
N2
23
194
if it is the included wiring harness the wires should have their numbers stamped on the jacketing and a sticker should designate the proper screw to mount it to in both the ATS and the generator housing. hooking these wires up incorrectly often results in blown fuses and/or damage to the control board in the generator.
Posted on Dec 01, 2009
  • 26 Answers
Just 4. I install generac switches and generators
Posted on Jul 09, 2009
The 4 wire you have in the cable are utility sense and the start circuit. the two extra terminals that you are talking about are likely the battery charge circuit
Posted on Mar 13, 2012
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
For these 4 control wires. How many watts do they consume. I have a generator 150ft away from the transfer switch, should these 4 18AWG control wires upsized?
No. They are fine. The voltage is 220. But the amperage is nearly nothing because its just for signaling the generator and switch when the powers out. I install, repair, and service generac products for a living.
Feb 10, 2011 | Generac 100 Amp 120/240-Volt Transfer...
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
I have a new Generac 20KW Propane generator with a rtse 200A3 automatic switch. I had an electrician install the switch and make the connections from to the generator. The generator is blowing the 7.5 amp...
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
Sep 02, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3 Logo
1,511 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
