HEATS FOR ABOUT A MINUTE,SAFETY THEMO.OPENS,CLOSES IN ABOUT 15 SECONDS,HEATS AGAIN,CYCLE CONTINUES. HAVE ALREADY REPLACED COIL SET,AND SAFETY THERMO./FUSE(53-1096).IF SAFETY THERMO.IS JUMPED FLAME STAYS ON(ONCE AGAIN IT IS A NEW PART).ALL VENTING IS CLEAN,AND OPEN. DOES THE THERMO.ONLY REACT TO HEAT??CANNOT POSSIBLY BE GETTING TO 240F IN A MINUTE OR LESS. ANY HELP OR SUGGESTIONS WOULD BE APPRECIATED.
Comments:
Sep 17, 2007
- PROBLEM FIXED Did not check exhaust vent(outside)flapper was door jammed shut, freed it,now dryer works perfect,total air flow keeps safety thremostat in operating range,no longer(overheats) opens, and shut burner down.Probably did not need new parts.Live,and learn.
-   How long did your fix work? I have cleaned the outside vent over and over and it gets clogged again in an inordinately short amount of time (4-6 wks of light to normal use).
-   Regulator26
I have this same exact problem, my husband and I just spent the better part of the afternoon trying...
(More)
I have this same exact problem, my husband and I just spent the better part of the afternoon trying to get the thing to work.
is the error I keep getting. I dismanted the front and cleaned out whatever dust and lint I could....
(More)
is the error I keep getting. I dismanted the front and cleaned out whatever dust and lint I could. The problem still exists. It will not start up the DRYER even tho I can press any number of options possible, Does anyone have any suggestions to FIX This?
Hi ,the drum belt tensioner and spring have fallen off, inside my Simpson dryer when I took it apart...
(More)
Hi ,the drum belt tensioner and spring have fallen off, inside my Simpson dryer when I took it apart to fix another problem.Is there a diagram showing where they should go? Thanks
lg Tromm DLE7177WM dryer, started with a plastic burning smell, then the machine lost power. The...
(More)
lg Tromm DLE7177WM dryer, started with a plastic burning smell, then the machine lost power. The dryer is only 2 years old
