Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
My at&t landline has a dial tone but cannot call
My at&t landline has a dial tone but i cannot make a call outside. I have removed dsl and all other lines and connected just the phone to the phone jack directly using a new cord. Still get a dial tone but cannot call.
  • Vtech Master
  • 4,201 Answers
Check dialing mode matches what exchange is set to DTMF suspect phone is set to dec = decadic or pulse
Posted on Oct 08, 2015
2 Suggested Answers
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
I have Epson SX600FW and am trying to set up the Fax capabilities plus have a phone attached to the printer. I connected the printer\fax Line to the BT socket and the phone to the EXT socket but got no...
https://www.epson.co.uk/support?productID=2933#manuals
Download Fax Guide.
Note instructions for DSL phone line is different than regular phone line. The fax manual there has pictures of how that is done.
If BT is faulty, they offer support:
From the UK: 0800 800 150*From outside the UK: +44 179 359 6931*
Our repair teams are open:
7 days a week, 24 hours a day
* The cost of the call depends on the country and network you're calling from.
http://www.bt.com/help/home/contactus/#/landline/fix-landline-problems
Feb 06, 2018 | Epson Stylus Multifunction Printer/...
How does one forward incomming calls on a uniden 2.4ghz cordless phone?
Cordless phones can not 'forward' a call to an outside line.
Forwarding must be controlled by the ATT, Verizon, or landline provider.
Please contact your provider to determine if you have call forwarding feature built into your service package.
Then, follow the instructions of your landline phone provider.
Here is the instructions for Verizon:
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
  1. Lift your telephone's receiver and listen for a dial tone.
  2. Press star.gif7.gif2.gif.
    Dial 1172 on rotary or pulse-dialing phones.
  3. When you hear the tone, set or change the Call Forwarding number by dialing the telephone number where you want your calls transferred.
    You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
  4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
    You will hear two short tones telling you that Call Forwarding is activated.
  5. Hang up the receiver.
Feb 16, 2011 | Cell Phones
Not able to ring out or recieve calls on landline 01772465172
Is there a dial tone? Have you tried plugging in outside in the NID(phone box) on the side if the house. Take a corded telephone out to the box if it has a test port to plug into. If it does, plug in. If you have a dialtone, then the problems inside with either the station wires or jacks, or other equipment that is plugged into the jacks. Remove all devises from the jacks if trouble is inside and take a known working phone and plug it into a jack. if it works, plug in another device, so on and so on. Be sure to check dial tone, break dial tone by pressing a button. Hang phone up and see if dial tone has returned. If not, then that piece of equipment is bad.
If no dial tone at the NID, then call in a trouble report of NO DIAL TONE to the telephone company of cable provider. To save money if trouble is inside, purchase the inside wiring maintenance plan and then have them come work on the phone lines. After the service is restored, call and cancel the maintenance. $5 and you're back in service, provided that's all the teleco charges for wiring maintenance.
Nov 30, 2010 | Lands Phones
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
No dial tone
Sep 04, 2009 | Vtech Lands Phones
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
Phones Dead but DSL OK
A short inside the house should also disable the DSL service, but you can rule out this possibility by disconnecting the inside wiring from the outside wiring at the entrance box. If you still can't get a dial tone when you clip onto the incoming wires, then you need to contact your local phone company to have them find the problem and restore your phone service.
Good luck...and I hope this is helpfull!!
Jan 26, 2008 | Lands Phones
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
398 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
