Question about HP LaserJet 2100 Printer
Not printing all text
It is not printig some section of the whole print area, in the middle
  • HP Master
  • 705 Answers
If you blank stripes in the vertical plane, it would suggest that toner or other foreign material has got onto the laser lens. Remover the toner and photo conductor units and look for the glass panel above the laser unit. Clean this with a tissue or soft cloth. You should find this gets you away. If not then the photo conductor is the next suspect to replace.
Posted on Sep 16, 2007
SOURCE:
Not Printig
When you select print, you should see a preview before it prints. Then you can check your settings. Select, print entire page.
Apr 17, 2010 | Dell 946 All-In-One InkJet Printer
When I send to print some file not printing, the plotter indiquet procesing and not printig ,plotter can scan, No. IP is correct, Submasc is correct, the conection is correct
before you print go to the page setup and din adjust the bottom or gutter and try to print preview and look carefully the area you want to print if completely present or try to uninstall the microsoftword and install again
regards
fdlixboy
Jul 08, 2009 | Xerox 8830 Copier
Incomplete printing
goto the maintenace section of your printer and then print maintenace page..or clean printhead option.
or
maybe your black ink cartridge is now low..replace it with a new one..if the problem still exist ..wipe the cartridge on a wet cloth in order to clean the clogs.that cover the nozzles..
May 12, 2009 | Office Equipment & Supplies
5610 printing just a line in the middle of the page, else blank!
wow..I could be the FIRST..I am impressed..NOT!
check to see if there is ink, by blotting the print head on damp paper towel.
otherwise..delete and reinstall the printer. could be a software problem.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Missing text lines
This is caused by the black part of the printhead getting clogged and it's very difficult to shift this.
My personal solution has been to switch to a dyebase ink instead of of the pigment ink that HP provide... but as a more practical matter it seems that this sort of clogging happens when the printer is located in a dry, overly warm environment where things like air conditioning, radiators, etc... dry out the air.
If possible, relocate the printer to a more ventilated, cooler area.
Running the cleaning routines should clear the blockage after a couple of times but it may well return so this is by no means a full fix.
Apr 07, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Gap in printing
the color ink cartridge has dried. replace it.
Nov 29, 2008 | Dell 924 All-in-One InkJet Printer
My Hp LaserJet 2600n stop black stop printig
the problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
Aug 26, 2008 | HP Color LaserJet 2600n Printer
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
HP LaserJet 2100 Printer Logo
67 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
